downshift to second gear noises
downshift to second gear noises Empty downshift to second gear noises
Post  zbob May 3rd 2014, 8:42 am
gentlemen, need help with stupid stuff, namely me! last fall I downshifted to second gear to help slow the car to make a corner while driving to fast. immediately got a ba-ding ding ding clink-clak pow bang noise. go ahead and laugh.
....so far it is not the driveshaft splines, u joints or end clips, not the diff pin or bolt, or spider gears or axle splines. rear is a 8.8 trac lock. no loose brake hardware on rear drums. water pump and alternator and factor duraspark distr have no loose parts floating around. flex plate and converter bolts present and accounted for.
.....unfortunately I live and a tourist area and spirited driving is not going to be overlooked while road testing now that spring is here. any thoughs on internal trans parts possibilities would be helpful. fwiw car is a 12 sec street/puss strip car. thanks, bobn
zbob
downshift to second gear noises Empty Re: downshift to second gear noises
Post  bigblok2000ranger May 3rd 2014, 5:56 pm
Broken band apply lever, broken band, broken planetary. Do you have all forward gears?
bigblok2000ranger
bigblok2000ranger
Post  zbob May 3rd 2014, 11:25 pm
thanks eric, drove really slow to get up the grave road to home, I did have at least one forward for sure to do that and reverse....bobn
zbob
Post  zbob May 8th 2014, 7:59 am
trans is sitting on the tranny jack. we shall soon see, lol. that is as soon as I get some help to muscle it out. I need a freakin hoist. laying on cement with the car on stands sucks nowadays. bobn
zbob
Post  bigblok2000ranger May 8th 2014, 4:07 pm
zbob wrote:trans is sitting on the tranny jack. we shall soon see, lol. that is as soon as I get some help to muscle it out. I need a freakin hoist. laying on cement with the car on stands sucks nowadays. bobn
Funny I have noticed that same issue and I think you have a few years on me.
When my band apply lever broke I found it and the dogbone lying in the pan. Good news is it is a really simple fix, bad news is the shaft it rides on requires the converter to be pulled to change it.
bigblok2000ranger
bigblok2000ranger
Post  zbob May 8th 2014, 11:10 pm
thanks for info eric. tranny is now along side of car. I think a well built c4 in it is in my future, lol. anyway I am gonna tear into it this weekend. I want to try my brand new mickey ts out and maybe wander down to us60. bobn
zbob
Post  Gregaust May 9th 2014, 6:08 am
Be very keen to see what you find  affraid
Gregaust
Post  zbob May 9th 2014, 8:10 am
I will definitely post what is dissemblogalated. bob
zbob
Post  zbob May 11th 2014, 8:47 pm
well not that anybody gives a ratsarse, the smooth base of the splined drum that supports the one way clutch is cracked. not sure is that is the real problem or not. hard to believe that could make that much of a racket. bobn
zbob
Post  whitefield May 11th 2014, 8:51 pm
zbob wrote:well not that anybody gives a ratsarse, the smooth base of the splined drum that supports the one way clutch is cracked. not sure is that is the real problem  or not. hard to believe that could make that much of a racket. bobn
In the bottom of the case ?
whitefield
whitefield
Post  zbob May 11th 2014, 8:55 pm
yes sir it was the drum I pulled out of the last clutch pack. funny the base was cracked but not the splined area the actually slides into those clutches.   I am about to start studying all the correct names of this stuff so I can put it all back with out left overs. kinda like the first time I pulled a carb apart forty years ago lol....bob
zbob
Post  whitefield May 11th 2014, 9:00 pm
zbob wrote:yes sir it was the drum I pulled out of the last clutch pack. funny the base was cracked but not the splined area the actually slides into those clutches.   I am about to start studying all the correct names of this stuff so I can put it all back with out left overs. kinda like the first time I pulled a carb apart forty years ago lol....bob
A lot of knowledge here and great people to help you ! Good luck
Here is a good pic
http://www.transmissioncenter.org/C6_Parts_Blow_Up_Diagram.htm
whitefield
whitefield
