CONVERTER THRUST CLEARANCE
CONVERTER THRUST CLEARANCE Empty CONVERTER THRUST CLEARANCE
Post  BIGBLOCKBOE May 6th 2014, 4:10 pm
Need proper converter to flexplate clearance for powerglide with BBF. I have seen info stating 060 ths and info stating 3/16. 532 stroker with 4000 stall on nitrous
BIGBLOCKBOE
CONVERTER THRUST CLEARANCE Empty Re: CONVERTER THRUST CLEARANCE
Post  David Cole May 6th 2014, 8:12 pm
1/8" to 1/4". I always try to shoot right at the middle with 3/16". I use a 3/16" drill bit as a go/no-go gauge.
Post  cool40 May 6th 2014, 8:21 pm
No less than 1/8"Imo...
Post  Frank Merkl May 8th 2014, 7:57 pm
your pushing your luck with a tight .125" , .060" way tight , put another blockplate in will give you another .095" ,with the .060" -now you'll have .155" still just a tic tight but should work !
Post  richter69 May 8th 2014, 9:06 pm
im at .100 w this current setup, so far so good.
1/8" min to 3/16" max is the norm.
CONVERTER THRUST CLEARANCE Empty Thanks fellas
Post  BIGBLOCKBOE May 9th 2014, 9:33 pm
i had 090 clearance with mid plate and had already thought about adding the starter plate and that is what I did after seeing the suggestion. ended up about 150. Pain in the but getting converter lined up in adapter bushing put long dowel pins in and that helped a lot. Thanks for the input .
BIGBLOCKBOE
