C-6 thrust
C-6 thrust
When rollerizing a C-6 trans, how much do the bearings vs thrusts add to durability, or is it primarily done to cut frictional losses?
Thanks, Sheldon G
Thanks, Sheldon G
STR-LGL-70- Posts : 223
Re: C-6 thrust
Thrust washers wear , contaminate the oil. Rollers don't and endfloat stays consistent. The rollers let a C6 spin over real free too
Gregaust- Posts : 626
Re: C-6 thrust
I may be wrong, perhaps Greg or Frank will correct me if I am, but I would think intuitively that a roller generates less heat than a thrust washer. Not a ton of heat overall, but localized at the metal surface.
This should keep the oil healthier and metals in better condition.
DeepRoots- Posts : 110
Re: C-6 thrust
Transmission stays way happier
Frank Merkl- Posts : 1524
» thrust clearance
» Camshaft end play
» Cam thrust plate options?
» CONVERTER THRUST CLEARANCE
» cam thrust plate
» Camshaft end play
» cam thrust plate
