I need Help Identifying my dads big block engines. He passed away
powerstrokeace
jc122078
My Dad left me a lot of stuff. The engine is a 429 with 68 on back. The block says Dove-A with a 5. It has DOOR-E on heads. It says "CJ" in the lifter valley. It is a 4 bolt main.
jc122078- Posts : 8
Re: I need Help Identifying my dads big block engines. He passed away
Well t sounds like a 429 cobra jet. It it could also be a super cobra jet as well. If I'm correct they have a standard 4 barrel carb and I think solid lifter cam?
Ace
Ace
powerstrokeace- Posts : 1496
jc122078 wrote:My Dad left me a lot of stuff. The engine is a 429 with 68 on back. The block says Dove-A with a 5. It has DOOR-E on heads. It says "CJ" in the lifter valley. It is a 4 bolt main.
your question is real bull shit.
you knew what that was 2 tears ago. thats when you tried to sell it and said what it was
i'm not wrong. you listed it for sale,was deleted for low post count 2 years ago.
Then post you had a DOVE block and SCJ heads in a members thread who wanted to buy a DOVE block
DanH- Posts : 1081
No Dan your wrong. I bet you didn't even read the discription. " Engines" . I have many 429 engines. Since nobody knew what they came out of I am asking again. This is just ford motor stuff not CSI.......
jc122078- Posts : 8
Based on the info given you have CJ heads and four bolt block. Whether you have full CJ or SCJ engine depends on what the other parts and their product numbers are. Detailed pictures of accessories with their detail info would help you get more info.
Calypso- Posts : 71
jc122078 wrote:No Dan your wrong. I bet you didn't even read the discription. " Engines" . I have many 429 engines. Since nobody knew what they came out of I am asking again. This is just ford motor stuff not CSI.......
i,m not wrong, your father passed away 2 year's or more. located in Va.
you did post that engine for sale here , got deleted for not having the required post count.
btw, no rules against CSI. good try on getting around the rules
DanH- Posts : 1081
Select/Unselect multi-quote
Reply with quote Re: WTB: Dove-A block or A-460
Post jc122078 on Fri Jun 29, 2012 1:59 am
I got dove-A Block for sale was dads, Cobra jet heads, 5 speed toploader for sale, in the for sale columb
jc122078
View user profile Send private message
D. Sea- Posts : 2768
windsor- Posts : 1167
» Need help with identifying a block
» I need some help identifying an engine block
» hello i just brought 2 BBF engines. new to them. which block to build?
» Edelbrock Pro-Flo 4 EFI #35680 for Ford 429/460 Big-Block Engines
» Edelbrock 35680 Pro-Flo 4 EFI system.
