leak
leak Empty leak
Post  motorhead May 21st 2014, 9:20 pm
I have a rebuilt 429 that has not been fired up yet. I have filled the coolant system and it has been setting for a few days now and I have a noticed a drop of coolant coming from the front of the bell housing. Since
Sunday it has leaked about 4 drops. Is this as bad as I think it is? Crying or Very sad
motorhead
leak Empty Re: leak
Post  bbf-falcon May 21st 2014, 9:33 pm
Start it,it might seal itself off. Check oil and radiator after it makes heat cycle.
leak Empty leak
Post  motorhead May 21st 2014, 9:38 pm
Thanks for the input. I'll keep you posted.
motorhead
leak Empty Re: leak
Post  69F100 May 22nd 2014, 12:34 pm
bbf-falcon wrote:Start it,it might seal itself off. Check oil and radiator after it makes heat cycle.
X2 Might be coming from the intake and down the back check good on the back of the engine at the oil port for the gauge and see if you see anything back there if not might be a head gasket seeping a little might stop after a heat cycle or 2
leak Empty Re: leak
Post  dfree383 May 22nd 2014, 4:25 pm
Pressurize at and see if you can find where it's leaking. Pull the plugs too
leak Empty Re: leak
