How thick of a wheel spacer
How thick of a wheel spacer Empty How thick of a wheel spacer
Post  tconnection May 24th 2014, 1:11 am
I have a rearend that has been cut down 2.5 on each side. I was going to mini tub and move the shocks but im thinking about staying stock suspension. How thick of a wheel spacer would I need to use with a 15-10-6.5 back space?
tconnection
How thick of a wheel spacer Empty Re: How thick of a wheel spacer
Post  crittersf1 May 24th 2014, 7:06 am
What kind of car? confused
crittersf1
crittersf1
Post  tconnection May 24th 2014, 9:50 am
Its an 89 mustang hatch.
tconnection
Post  tconnection May 24th 2014, 2:41 pm
The rearend is a moser M9 40 spline gun drills. Im looking toward leaving the car ss and go with some qa1 DA coil overs in the front and some qa1 stockers in the rear and run a msd programmable al2.
tconnection
Post  Mike R May 24th 2014, 3:37 pm
I'm just guessing, 2.5"? It seems that a 10" wheel with 6.5" back space is what works with a stock width, so go with a 4" back space wheel. I have 12.5x28 ET Streets on 6.5" backspace wheels on my Fairmont with 1" off each end and they barely clear the pinch weld. I mini tubbed the car so there's plenty of room on the inside.
Post  DILLIGASDAVE May 25th 2014, 2:25 am
Using wheel spacers with 11/16 x 5/8 drive studs is usually ok as long as the spacer isn't too thick. But using spacers with the smaller regular 1/2" wheel studs isn't the best idea.
