rear sump oil pan
rear sump oil pan Empty rear sump oil pan
Post  jasonf June 4th 2014, 7:56 am
I have a friend with a factory looking pan on it. It doesn't look like the standard rear sump pan I have ever seen. Could this be a boat pan or is is just modified? He has no idea of the capacity other than he has put 9 qts in it and still not on the dipstick. He has no ideal if the dipstick is even correct.
So he is looking for a new rear sump pan or if he could figure out this pan that would be great as well.. Any suggestion would be appreciated.
rear sump oil pan Johnny460oilpan_zpsdeca898d
rear sump oil pan Empty Re: rear sump oil pan
Post  lghting94 June 4th 2014, 7:59 am
Not positive on this but that kinda looks like the dump truck pan(12 qts)
lghting94
lghting94
Post  hookin78 June 4th 2014, 8:05 am
Yes , this is a 370-420 Two ton truck pan..... I have made a few truck pull pans out of them, made them deeper wider , etc.
If trying to use the front sump dipstick (timing cover dipstick) it doesnt really work.
I weld bungs on the side to utilize a clear verticle tube as a site level gauge, that may not be convienient in your application dont know
These pan work well with a stud mounted windage device, I personally use the black max solid one from MPG heads
hookin78
Post  jasonf June 4th 2014, 12:16 pm
I got him to send me a couple more pics. Here is the dipstick. I have an 8 qt boat pan and I can not believe that thing holds 12 qts.
rear sump oil pan 10264300_10203134865666223_1871184388813725206_n_zpsb5c36f79
rear sump oil pan 10253834_10203134779144060_8098601567428696550_n_zps0b6581ae
Post  lghting94 June 4th 2014, 12:58 pm
That looks like a newer model dipstick tube and for sure a newer model dipstick so they will most likely not read correctly in that pan. I had one of those pans(highly modified inside) on my old mud truck I ran 9 qts of oil in it and it didn't touch the original dipstick.
lghting94
lghting94
Post  hookin78 June 4th 2014, 1:06 pm
lghting94 wrote:That looks like a newer model dipstick tube and for sure a newer model dipstick so they will most likely not read correctly in that pan.  I had one of those pans(highly modified inside) on my old mud truck I ran 9 qts of oil in it and it didn't touch the original dipstick.
yup same experience
hookin78
Post  bbf-falcon June 4th 2014, 1:40 pm
Unless he really needs the capacity,I would get another pan Jason. I have a stock rear sump pan if you need one.
Post  jasonf June 4th 2014, 2:07 pm
bbf-falcon wrote:Unless he really needs the capacity,I would get another pan Jason. I have a stock rear sump pan if you need one.
How much do you want for it Rick?
Post  bbf-falcon June 5th 2014, 1:35 am
Just tell me where you want it sent too. Wink
