SV1 on mafia intake
SV1 on mafia intake Empty SV1 on mafia intake
Post  FORDMUD June 9th 2014, 10:11 am
What does it take to make it work? I thought I remembered seeing it takes some grinding.
FORDMUD
FORDMUD
SV1 on mafia intake Empty Re: SV1 on mafia intake
Post  bbf-falcon June 9th 2014, 10:26 am
2"Open spacer will work.
Post  514Fox87 June 9th 2014, 4:20 pm
I have a 4" SV-1 on mine and have no problems. Just make sure you put the tapered spacer on right. If not carb. gets stupid. I learned he hard way.
514Fox87
514Fox87
Post  FORDMUD June 9th 2014, 5:32 pm
1" spacer?
FORDMUD
FORDMUD
Post  514Fox87 June 9th 2014, 7:06 pm
It came with 1/2 inch spacer and that is all I run.
514Fox87
514Fox87
Post  bbf-falcon June 9th 2014, 11:11 pm
I have the tapered spacer and a 1" under it.
Post  FORDMUD June 12th 2014, 5:08 pm
Would cutting the top out square change the distribution much? Seems Patrick is against any form of a cloverleaf with the sv1.
FORDMUD
FORDMUD
Post  bbf-falcon June 13th 2014, 7:20 am
I agree w/Pat. A clover leaf would hurt imo. Open spacers aren't that expensive.
Post  Diddly June 13th 2014, 2:45 pm
I ground the cloverleaf out of mine and run with no spacer.
Diddly
Post  FORDMUD June 13th 2014, 2:59 pm
I don't mind running a spacer(s) or doing a little grinding. I'll probably do both. Very Happy
FORDMUD
FORDMUD
