Would it be worth keeping?
Would it be worth keeping? Empty Would it be worth keeping?
Post  jones June 30th 2014, 7:09 am
I need more room in the shop and I'm trying to decide if I should keep this 460. It's a 1979 460 that probably has bad cam bearings causing zero oil pressure. The engine ran good besides the oil pressure. I would love to sell it because I could darn sure use the money, but I don't know the first person that would need it. So now I'm trying to decide if I should keep it or sell it for scrap. The only thing bad about the block is that it's had a leaking water pump for so long that it has worn a groove in the block face where the water pump bolts.
Would you keep it? If I sold it what would be a good asking price? (It's basically a long block.)
jones
Would it be worth keeping? Empty Re: Would it be worth keeping?
Post  maverick June 30th 2014, 10:03 am
Cam bearings are cheap and the water leak is an easy fix.  SOMEBODY would like to have it.  I hate to see stuff go to the scrapyard just to make room. Mad
That D9 block may not mean much to some guys, but to others...well, you know.
BTW, I've been running a D9 block in the 5's for years.
Post  jones June 30th 2014, 10:53 am
I'd like to keep it because of the D9 block.
I'm sure it wouldn't cost much to just send it to the machine shop and have it freshened up. Thought about doing that and putting in a plastic bag. Just as sure as I get rid of it I'll need it.
jones
Post  maverick June 30th 2014, 11:39 am
I wouldn't spend the money on it 'til I had plans for it. You could just knock the heads off and store it. Easier to store and move that way
Post  dfree383 June 30th 2014, 11:45 am
I'd just strip it down and save the block and a few pieces and scrap the top end. They take up a lot less space sitting on end with out heads and a bunch of stuff hanging on them.
Post  jones June 30th 2014, 5:14 pm
dfree383 wrote:I'd just strip it down and save the block and a few pieces and scrap the top end. They take up a lot less space sitting on end with out heads and a bunch of stuff hanging on them.
Thats a good idea.
jones
Post  kim June 30th 2014, 11:01 pm
Got two d9's as my work bench base............. just in case.
kim
