Titanium valves with hydraulic cam ?
JBR-3
Titanium valves with hydraulic cam ? Empty Titanium valves with hydraulic cam ?
Post  JBR-3 July 11th 2014, 11:15 pm
Last edited by JBR-3 on February 22nd 2020, 1:58 am; edited 1 time in total (Reason for editing : .)
JBR-3
Titanium valves with hydraulic cam ? Empty Re: Titanium valves with hydraulic cam ?
Post  dfree383 July 12th 2014, 12:05 am
The lifter is where the problem is at
Post  DanH July 12th 2014, 6:24 am
dfree383 wrote:The lifter is where the problem is at
the lifter becomes the problem only when slack becomes present.. lighter valves help keep the slack out
DanH
Post  torino501 July 12th 2014, 8:25 am
with that being said why are there no 5/16 valve stem out there for any of the bbf heads or is there?(lighter)
torino501
Post  dfree383 July 12th 2014, 9:33 am
You can order anything you heart desires.
Post  JBR-3 July 12th 2014, 10:17 pm
Last edited by JBR-3 on February 22nd 2020, 1:59 am; edited 1 time in total (Reason for editing : .)
JBR-3
Post  DanH July 13th 2014, 6:14 am
torino501 wrote:with that being said why are there no 5/16 valve stem out there for any of the bbf heads or is there?(lighter)
T?F A460 heads, can be had new with 5/16 stems part#'s for the ones that have them, check with Summit.
5/16 stems years ago were common for the Clev & BBF plus chevys
DanH
Post  KY JELLY July 13th 2014, 9:04 am
Are you running out of cam or are you running out of spring ?
KY JELLY
KY JELLY
Post  dfree383 July 13th 2014, 1:39 pm
JBR-3 wrote:Dfree,
What is the problem with the lifter ?
They pump up because things are happening too fast. Save yourself a lot of agravation and just go with a mechanical flat tappet.
Plus your looking at most regular headed 460 based engines peak at about 6500-6800 rpm anyway.... Within the realm of hydraulic stuff. I think you solving a problem for no reason.
If you have the valves by all means use them, but I wouldn't go out of my way on a hydraulic flat tappet your better of spending the time on a number if other areas.
Post  rmcomprandy July 13th 2014, 1:57 pm
This sounds like a cure seeking a problem...  Wink
Post  dfree383 July 13th 2014, 2:35 pm
rmcomprandy wrote:This sounds like a cure seeking a problem...  Wink
Exzackary!
Post  DanH July 18th 2014, 5:33 am
why not run the heavy valves / reatainers ?
A lighter valve/retainer can use  lighter spring pressure, sounds like a good reason to not use the heavy parts.
wouldn't less springs pressure help a flat tappet cam live?
DanH
Post  KY JELLY July 18th 2014, 8:29 am
It takes an aggressive lobe to turn the higher rpm , valve weight or materials has more to do with the spring living than the lifter following the cam .
KY JELLY
KY JELLY
Post  rmcomprandy July 18th 2014, 9:24 am
KY JELLY wrote:It takes an aggressive lobe to turn the higher rpm , valve weight or materials has more to do with the spring living than the lifter following the cam .
Actually, LESS aggressive, lazy lobes which are large in area will run at higher RPM easier, with less valve spring pressure.
Giving up a lot of torque is the major problem with running them.
