2000 Ranger frontend swap to a tube strut frontend
+7
whitefield
72mav
70FB
11 posters
 2000 Ranger frontend swap to a tube strut frontend  Empty 2000 Ranger frontend swap to a tube strut frontend
Post  69F100 July 17th 2014, 3:13 am
I am beginning the frontend swap I have been planning to do for the last 3 years I am using a Mazda RX 7 5 lug frontend . I will be using the struts with a coil over conversion kit the kit is the same as a mustang kit, the aluminum lower a-frames and mounts, the wheel hubs are aluminum also with 4 1/2'' bolt pattern,  the brake calipers are 4 pistons and are also aluminum. Should help lighting the truck up some plus I am trimming some more on the cab going to fix it so I can make the headers exit out the fenders behind the tires. I got the engine out tonight start cutting out the frontend tomorrow night after work.
 2000 Ranger frontend swap to a tube strut frontend  0717140206_zpskvu21lcp
 2000 Ranger frontend swap to a tube strut frontend  0717140205a_zpstiyruzw0
 2000 Ranger frontend swap to a tube strut frontend  0717140205_zpsgeixv4gr
 2000 Ranger frontend swap to a tube strut frontend  Empty Re: 2000 Ranger frontend swap to a tube strut frontend
Post  cool40 July 17th 2014, 9:23 am
Saw time!  bounce
Post  69F100 July 17th 2014, 11:59 am
I marked the frame 50'' on each side to have a reference mark from center of the spinal forgot to get the overall measurement to the bumper bracket will do that tonight plus get the measurement from side to side off the face of the rotor to make sure I get the tires set right in the fenders. I will still have the side to side measurement as I am cutting the frame right in front of the mid plate mounts.
 2000 Ranger frontend swap to a tube strut frontend  0717141145_zpskdndlnwo
Post  69F100 July 18th 2014, 1:44 am
Old frontend is gone took about 1 1/2 hours to get it out got a little grinding to do but I think made enough noise tonight. Going in the morning to get the tubing so I can start mocking the frontend up.
 2000 Ranger frontend swap to a tube strut frontend  0718140049a_zps3duicpxz
 2000 Ranger frontend swap to a tube strut frontend  0718140049_zps6zdibw9x
Did cut the corner out of the right side to make room for the header to exit
right side
 2000 Ranger frontend swap to a tube strut frontend  0718140018_zpsqx3g5glb
left side
 2000 Ranger frontend swap to a tube strut frontend  0718140018a_zps1alrt1lc
Post  cool40 July 18th 2014, 9:32 am
Ain't no turning back now....I figure your using 2x3 rails?
Post  69F100 July 18th 2014, 12:27 pm
Yes 2x3 it will be setup a little like what Doug did on the Yellow Banana
Post  70FB July 19th 2014, 8:09 am
Sweet. Fiberglass or steel fenders?
70FB
70FB
Post  69F100 July 19th 2014, 10:00 am
70FB wrote:Sweet. Fiberglass or steel fenders?
The factory steel fenders they are light
Post  69F100 July 19th 2014, 4:15 pm
I got the new front runners ordered and new longer wheel studs should have them Monday from what Summit said get them mounted Tuesday before work and start back on the truck Tuesday night after work. I have to work this weekend so no worky on the truck until Tuesday anyway.
Post  72mav July 19th 2014, 8:25 pm
What front runners did you order? Jegs have their own line now for skinnies. I just love mine.
72mav
72mav
Post  69F100 July 20th 2014, 12:08 am
M/T 25x4.5x15
Post  HorsinAround July 22nd 2014, 3:02 pm
Keep those pics coming. I'd like to do something like this next winter.
http://www.frontpagefab.com
Post  69F100 July 23rd 2014, 12:48 pm
I will be taking pics as I go and posting
Post  69F100 July 24th 2014, 3:14 am
Went out tonight and did a little mock work and tack a bracket together to start  figuring out on how I wanted to mount the frontend. Got the tires mount today so now time to get the rest of the brackets built and welded up and start mounting things.
 2000 Ranger frontend swap to a tube strut frontend  0722140041_zpsmtjwdpv2
 2000 Ranger frontend swap to a tube strut frontend  0722140040_zpsuf02slc6
 2000 Ranger frontend swap to a tube strut frontend  0724140008_zpseu0srrbn
 2000 Ranger frontend swap to a tube strut frontend  0724140158_zpsgueacxwo
 2000 Ranger frontend swap to a tube strut frontend  0724140159_zpsoe9y5qm4
 2000 Ranger frontend swap to a tube strut frontend  0724140203_zpsaf5p6jai
 2000 Ranger frontend swap to a tube strut frontend  0724140206_zpszyrv28qv
 2000 Ranger frontend swap to a tube strut frontend  0724140159a_zpshks3l5y9
Post  whitefield July 24th 2014, 10:17 am
Looking good !  afro
whitefield
whitefield
Post  69F100 July 25th 2014, 1:42 am
Got the rest of my brackets cut out tonight started tacking 2 together when I herd sound like a shotgun go off talking about scaring the crap out of you. It was one of the old trailer tires I had put on the frontend when I rolled it out the shop it was only about 10 foot from my back when it blew.
 2000 Ranger frontend swap to a tube strut frontend  0725140004a_zpsgav9va5c
 2000 Ranger frontend swap to a tube strut frontend  0725140004_zpsysskga43
Post  cool40 July 25th 2014, 1:15 pm
Laughing  sounds like a youtube moment!
Post  DILLIGASDAVE July 26th 2014, 3:47 am
Don't forget that on top of mocking up the front tire/wheel/strut/lower control arm assembly at the desired race ready ride height & caster/camber angles, you also have to remove the strut spring & compress the strut shaft X amount to set how much full extension & full compression travel you want to have from the race ready ride height setting.
If the camber/caster can't be adjusted with the OEM lower control arm, then an adjustable CC spherical bearing top plate/mount assembly will have to be used. You will loose some engine clearance room with the adjustable CC plate/mount setup vs a simpler weld on spherical bearing top cup mount, (or a full chassis car type rubber-urithane washer/biscuit top mount).
But if the OEM RX7 strut/spindle assembly has the strut body's centerline offset from the lower balljoint's centerline, (like the Fox/SN95 stuff has) then some form of a spherical top mount was going to be needed anyway. The full chassis car washer/biscuit type top mounts should only be used if the strut body & lower balljoint are all on the same centerline.
Post  69F100 July 29th 2014, 12:52 am
Dave the only adjustment will be with the top of the strut I am working on making a adjustable plate fore the top. It has a 10* built in the spindle I am also leaning it back 10*. My buddy Rick aka 557mazda set his up like this and I am trying to set mine a close to his as I can, his works good on his car. I working on building my mount so it is adjustable incase I need to adjust it some, I should be able to get back on it in a few days. I got to move the holes up about a 1'' on the lower bracket to get the lower control arm  right when I get the engine back in.
If you happen to see anything else let me know easier doing right the 1st time instead of cutting and moving stuff.
Post  69F100 August 2nd 2014, 4:57 pm
I got a little more done at least it on all fours now still got to mount the rack and add 2 bars at the top strut mount.
 2000 Ranger frontend swap to a tube strut frontend  0802140221a_zpsd5rpkf34
 2000 Ranger frontend swap to a tube strut frontend  0802141558b_zps2dqnevrk
 2000 Ranger frontend swap to a tube strut frontend  0802141558_zps27lpu0fj
 2000 Ranger frontend swap to a tube strut frontend  0802141559_zps6b4i2nda
Post  gmsmkr August 2nd 2014, 8:57 pm
That looks great
gmsmkr
gmsmkr
Post  69F100 August 3rd 2014, 8:24 pm
Thanks ,The flat bar is a chore to work with one thing the brackets will not be flexing. Not sure what kind of steel it is but it will not bend with out being cherry red. It is some my boss gave me a while back it will eat up some drill bits to trying to drill it. I went through 3 bits finally brought the brackets back to work and drilled them out with a $50 bit for stainless. We tried bending a peace that was 1 1\2x 3" without heat the 4 lb hammer would just bounce off without even thinking about bending it without heat.
Post  whitefield August 3rd 2014, 8:26 pm
Looking good and keep,the picks coming !
whitefield
whitefield
Post  gmsmkr August 3rd 2014, 8:36 pm
69F100 wrote:Thanks ,The flat bar is a chore to work with one thing the brackets will not be flexing. Not sure what kind of steel it is but it will not bend with out being cherry red. It is some my boss gave me a while back it will eat up some drill bits to trying to drill it. I went through 3 bits  finally brought the brackets back to work and drilled them out with a $50 bit for stainless. We tried bending a peace that was 1 1\2x 3" without heat the 4 lb hammer would just bounce off without even thinking about bending it without heat.
Sounds like some T-1 steel we use a lot of that also it is some good stuff...
gmsmkr
gmsmkr
Post  Mike R August 4th 2014, 9:35 pm
Looking good Jim cheers cheers cheers
