1988 4 cylinder strut v/s 1998 V6 strut
1988 4 cylinder strut v/s 1998 V6 strut Empty 1988 4 cylinder strut v/s 1998 V6 strut
Post  tconnection January 19th 2015, 3:20 pm
These are both mustangs but one is a fox and the other is a sn. Is both struts the same? I got the spindles off the sn hooked and want to know if the fox struts bolt up to the sn spendle.
tconnection
1988 4 cylinder strut v/s 1998 V6 strut Empty Re: 1988 4 cylinder strut v/s 1998 V6 strut
Post  gmsmkr January 19th 2015, 3:29 pm
They will work just need to shim the Fox struts at the spindle mount.
gmsmkr
gmsmkr
Post  tconnection January 20th 2015, 10:54 pm
Don't seem like the holes are matching up. I had to lower the bottom of the lower hole. I did shim them. Plus I gotta get more brake lines. For sure these struts are temps.
tconnection
Post  tconnection January 21st 2015, 11:27 am
As for the sn front brake and spendle setup, do the weld 31/2 rims require spacers behind them?
tconnection
Post  tconnection January 21st 2015, 11:41 am
I mean what required to get them bolted on? They r touching the caliper bracket.
tconnection
Post  gmsmkr January 21st 2015, 12:42 pm
With that set up you can grind the outer lip of the caliper bracket or use 1/4 spacer I can get pics for you tonight on what to grind if you like.
gmsmkr
gmsmkr
Post  tconnection January 21st 2015, 2:01 pm
Pics would be great and as for spacers, wold washers work?
tconnection
Post  gmsmkr January 21st 2015, 6:19 pm
I would not use washers use the plates so that it spreads the load....
here are the pics of what you need to grind just do get them to thin if you need to cut much just run the plate spacers.
1988 4 cylinder strut v/s 1998 V6 strut 20150121_160947_zps1j9wfy7g1988 4 cylinder strut v/s 1998 V6 strut 20150121_161002_zpsjeiz5ylv
gmsmkr
gmsmkr
Post  gmsmkr January 21st 2015, 6:20 pm
Pic of spacer plate
1988 4 cylinder strut v/s 1998 V6 strut 20150121_161048_zps5wm5rlkj
gmsmkr
gmsmkr
Post  tconnection January 22nd 2015, 12:53 am
I didn't think it was gonna cost this much to go 5 lug. But anyway a 1/4 off that bar will leave it fairly thin. How thin of a plate do they offer? Maybe grind some and go with a 1/8 thick spacer. That 1/4 shouldn't stick out so far to notice, should it? So it wouldn't be good to just cut it off?
tconnection
Post  gmsmkr January 22nd 2015, 2:36 am
I wouldn't just cut it off it ties the out side together that bracket has already had a 1/8 trimmed off.
You can buy a 1/8 inch spacer I think most parts stores carry the 1/4 in stock or most around here do
gmsmkr
gmsmkr
Post  whitefield January 22nd 2015, 7:52 am
I just did a sn95 5 lug conversion and I have never had to grind on those brackets or use spacers.
If the wheel hits those it is the wrong wheel get the right wheel.
Brakes steering and suspension are safety and you should never grind heat or bend ! Evil or Very Mad
whitefield
whitefield
Post  tconnection January 22nd 2015, 8:56 am
I bought those 31/2's from butterbean. They have the 1.750 bs.
tconnection
Post  gmsmkr January 22nd 2015, 9:36 am
whitefield wrote:I just did a sn95 5 lug conversion and I have never had to grind on those brackets or use spacers.
Its very common for them to be ground down and some spacers.... for your first 5lug swap you did good to have the right offset wheel.
Back space and offset are different
gmsmkr
gmsmkr
Post  tconnection January 22nd 2015, 2:27 pm
Looks like I'm having to go 5/16 plus trim some. Does the inside Dia of the spacer have to be exact for the center hub dia?
tconnection
Post  whitefield January 22nd 2015, 3:34 pm
Not my first 5 lug maybe 21 first LOL ! Laughing
If it is going fast and has to stop Fast I don't recomend grinding or spacers ! Evil or Very Mad
There is a purpose for that being there and it beaing that thick.
whitefield
whitefield
Post  tconnection January 22nd 2015, 8:28 pm
Well I did think that this set would be the final setup. But it gonna have to do for now till I get some strange or some that's perfect. I sure ain't buying no more rims.
tconnection
Post  jbozzelle January 22nd 2015, 10:53 pm
From what I recall that piece of the caliper bracket can be cut off completely... seems like a bunch of people have done it with no issues...
Also, the struts should bolt up the same. The SN95 spindle is thinner at the strut bolting point. And from what I remember the SN95 strut has approx. 1' more travel.
John
Post  tconnection January 23rd 2015, 7:43 am
Is any of you guys on here running these brakes with that bracket bar cut off?
thanks
tconnection
Post  jbozzelle January 23rd 2015, 8:22 am
I would like to know for sure too. I have a SN95 setup that is about to go under the front of my Futura with a set of Pro Stars as well.
Post  gmsmkr January 23rd 2015, 9:11 am
We cut some off one time and the bracket started opening up after around 12 pass on my nitrous car it was running 6.50s in the 1/8 and getting faster when we noticed the bracket had stress cracks.
gmsmkr
gmsmkr
Post  gmsmkr January 23rd 2015, 9:13 am
tconnection wrote:Looks like I'm having to go 5/16 plus trim some. Does the inside Dia of the spacer have to be exact for the center hub dia?
No it does not
gmsmkr
gmsmkr
Post  tconnection January 23rd 2015, 10:19 am
Well so far I got the 5/16 and still had to grind some but not as much as if I was to have used th he 1/4. Now to figure out what length wheel nuts to get.
tconnection
Post  jbozzelle January 23rd 2015, 10:49 am
gmsmkr wrote:We cut some off one time and the bracket started opening up after around 12 pass on my nitrous car it was running 6.50s in the 1/8 and getting faster when we noticed the bracket had stress cracks.
Thanks. I'll check it out on mine. maybe I'll weld a piece of flat plate in there.
