2000 Ranger frontend swap to a tube strut frontend
+7
whitefield
72mav
70FB
11 posters
Page 2 of 2 Previous  1, 2
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 Empty Re: 2000 Ranger frontend swap to a tube strut frontend
Post  69F100 August 5th 2014, 12:04 am
Thanks Guys
Got the tubing today to go from the roll cage down to the chassis for the upper strut mount one of my brother's friends had some left over from his old Panel Wagon up grade. That save me from having to order the tubing nobody around here stocks roll cage tubing. My heim joints for the rack should be here tomorrow I am going to use heim joints instead of tie rod ends. Going to try to finish all my welding this weekend on it. I got a eye Doctor appointment Thursday to find out when they going to remove the cataract off my right eye I have lost almost all sight in my right eye so it time to get rid of it. The Doctor said I didn't need to do any welding after he removes the cataract for about 3 weeks to let the eye heal. I have had enough trouble out of it so I am going to do what he tells me to do. So I am trying to get the welding done before I have the surgery on it.
Post  69F100 August 5th 2014, 12:56 pm
got the up right cut one in place finish the other side and weld them in tonight.
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0805141206_zpseuufhb1n
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0805141205_zpsw16wot3z
Post  69F100 August 7th 2014, 11:23 am
Got the up rights in now time to get the rack set up and get the steering hookup to the steering wheel. May have to change the mount under the dash some and change the angle it comes. Going to try to get the rack finished this weekend and paint the chassis up to the front cross member. I still have to get the cell mounts and bumper mounts welded on but that will be after I get the engine set in and rad mounted back in.
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0806140151a_zpsjszrksrt
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0806140151_zpspb8jtv9p
Post  larry552 August 7th 2014, 1:52 pm
Looking good man
larry552
larry552
Post  69F100 August 13th 2014, 4:06 am
Well got the frontend taken apart and painted tonight it has 2 different colors but hard to see in the pics the roll bars are lighter than the chassis. I will go out and repaint the chassis in the morning before I go to work you can see in the pics the over spray from the bars. I left the front cxm half painted I still got to add mounting brackets for the fuel pumps and fuel cells and one brace for the grill. I will add them once the engine is back in for I can get everything place right after the front fenders and grill back on. I start put the frontend back under it tomorrow night when I get off.
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0813140332c_zpsklguj4ao
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0813140332_zps2wozesjl
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0813140332b_zpsd36zrgld
Post  Mike R August 13th 2014, 6:58 pm
Looking good Jim
Post  69F100 August 16th 2014, 11:35 pm
Engine back in working to get the steering work out I get back on it Monday night got work night shift all weekend. I will have to rebuild my headers but that is OK as I wanted to change them to exit the fenders any how plus the will be lighter for some more weight loss.
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0816141722_zpsmjqgisl5
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0816141721_zpsttqlfbgp
Post  cool40 August 19th 2014, 3:10 pm
I think you want to get back on the track! Good progress!  Cool
Post  69F100 August 19th 2014, 6:26 pm
Trying to get all the welding done got to have eye surgery Monday and the doc told me no welding for 6 to 8 weeks. I give it a couple of weeks then if I need to weld something I use my patch and weld with one eye.    Razz
Post  cool40 August 20th 2014, 1:43 am
69F100 wrote:Trying to get all the welding done got to have eye surgery Monday and the doc told me no welding for 6 to 8 weeks. I give it a couple of weeks then if I need to weld something I use my patch and weld with one eye.    Razz
you better do what the doc tells you!  sunny
Post  69F100 August 20th 2014, 4:11 am
I should have the welding done Saturday except for the headers going to get a new header kit to build the new set plus I need some CJ flanges. I did get the radiator in, fenders back on, grill in and start on the bumper. The bumper bracket has been a pain in the rear to get them mounted right. First my regulator on torch  decide to go crazy finally got it half way working and cut the brackets off the old frontend and trimmed and ready to weld on.
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0820140315_zpsqyuvghq6
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0820140317_zps7ec0atnc
Post  bigblok2000ranger August 21st 2014, 11:55 pm
Looking good Jim, one thing that always annoyed me was the front wheel wells are so dammed big I seriously thought of closing them up a little.
Is that a Harbor Freight aluminum jack in the foreground? If so how do you like it?
bigblok2000ranger
bigblok2000ranger
Post  69F100 August 22nd 2014, 12:03 am
Yes it is a HF and I like it light and easy to move around I also bought the alum jack stands to. I have lifted my Tahoe with it and my f250 with the 7.3 pick both up with ease. I may never buy another steel floor jack it easy on the back loading it in the truck for race days. I move my front tires back 1'' it helps the look a little, I wish now when I bought the front runners I would have went with 26s instead of 25''.
Post  69F100 August 22nd 2014, 2:57 am
Got the front bump brackets welded on and the fuel cell brackets mounted. I get the primer plus fuel cell and pumps mount tomorrow and finish the steering Saturday. I will start buttoning the engine compartment up while my eye is healing and paint the front of the chassis. Should be able to start back on it Wed and get everything done except for the new fender exit headers
  2000 Ranger frontend swap to a tube strut frontend  - Page 2 0822140156a_zpsyxqwprhb
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0822140156_zpstd2tazem
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0821142358_zpsg3n5mo98
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0821142357a_zps5imrvqsr
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0821142357_zpswgktpj1i
Post  HorsinAround August 22nd 2014, 8:43 am
Looking good!
Without the core support, how are you attaching the headlight buckets and grill?
http://www.frontpagefab.com
Post  bigblok2000ranger August 22nd 2014, 9:23 am
Not Jim, but there is a fiberglass piece that goes all the way across the fenders it tucks up inside the grill real nice.
Jim I had 26's on mine and was seriously considering 28's just to fill the wheel well better, but I had already set all the suspension up with the 26's.
bigblok2000ranger
bigblok2000ranger
Post  69F100 August 22nd 2014, 11:23 am
Alen I got the grill back out I try to think and get a pic of it and post
Post  69F100 August 23rd 2014, 3:28 am
I have 5 bolts that holds the grill and head assy. 2 on each sides that goes into the fenders and 1 that goes in the center to a peace of 3/4x3/4 angle iron that is welded to the chassis. Got all the brackets welded on and painted tonight tomorrow I will pull the drivers fender back off and start hooking the rack to the steering wheel.
here is a pic of the grill assy.
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0822142326a_zpsrydj9zfk
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0822142326_zpsw1mangnc
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0823140220_zps7urdcg1b
the pegs you see is what hold the radiator on the bottom
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0823140220a_zpso7goiuh6
Post  69F100 August 24th 2014, 9:15 pm
We got the steering column figured out yesterday Rick came over and between both of us we figured it out it will only have 1 u-joint. I cut out all of the old column I got to pick up a peace of 3/4''x48'' chromoly tubing to finish it. When I get the tubing I'll get a friend down the road he is 91 years old to make a bushing for it that I can bolt in instead of welding it.
My brother came by and gave me a new toy it be my pit bike
 2000 Ranger frontend swap to a tube strut frontend  - Page 2 0823142037_zpssejexvu9
Post  HorsinAround August 25th 2014, 9:18 am
Thanks for posting the grill pictures.
Post  69F100 August 25th 2014, 1:53 pm
No problem if you have any questions on the front end swap just let me know I will answer the best I can.
