lca location?
lca location? Empty lca location?
Post  stanggt July 23rd 2014, 11:27 pm
86 fox with double adj uppers and megabite lowers with moroso trick rear springs, car sits to high and has about a 3 inch spread between bolts. whats best way to lower to get the lcas more level? change out the springs?
stanggt
stanggt
lca location? Empty Re: lca location?
Post  larry552 July 24th 2014, 10:10 pm
Get you a set of V8 springs and cut one coil out
larry552
larry552
Post  whatbumper July 26th 2014, 11:16 pm
The best way is to ditch the lowers and start over. They use a relocated rear on the lower to get a huge antisquat number.
Post  stanggt August 27th 2014, 8:38 pm
Double adj. Uppers and lowers from team z with a coil cut off factory v8 springs. Beautiful! !!
stanggt
stanggt
Post  whatbumper August 28th 2014, 4:29 pm
stanggt wrote:Double adj. Uppers and lowers from team z with a coil cut off factory v8 springs. Beautiful! !!
awesome
