A-head 547
+7
larry552
Dark Horse of Apocalypse
sg86coupe
11 posters
A-head 547
I've been buying for over 4 years and i'm getting close.
A-460 block new, machine work by Ted at Engine Systems
Scat Forged 4.300 crank
Scat Forged H-beams rods both from Adney
Trick Flow A-460 heads cnc ported 2.40 intake 1.88 exhaust valve job by Philip Oakley
Custom ground solid roller cam from Lem .470 intake & exhaust
Comp Cams Ultra Pro Mag XD rockers 1.8
No intake yet
1050 hp Holley dominator
no pistons yet thinking 14.5 or 15 compression
Will be going in a hard tail dragster, any guesses on power or et's
thanks Stacy
No intake yet
thanks Stacy
sg86coupe- Posts : 184
Re: A-head 547
You are leaving power on the table w/carb. i understand if thats what you already have. 1250 would work better imo. Watch that big int. valve w/bore on the 547. Power should be good . Whats the weight?
Re: A-head 547
Go 4.600 bore and make it a 572. You want the big bore with the big valves.
Re: A-head 547
dfree383 wrote:Go 4.600 bore and make it a 572. You want the big bore with the big valves.
xxxx2. Especially now,since you haven't bought pistons yet.
Re: A-head 547
bbf-falcon wrote:You are leaving power on the table w/carb. i understand if thats what you already have. 1250 would work better imo. Watch that big int. valve w/bore on the 547. Power should be good . Whats the weight?
Yessir. Big bore, big carb for big hp.
maverick- BBF CONTRIBUTOR
Re: A-head 547
4.5" bore with a 4.3" stroke right? Isn't the bore big enough for those valves or will he still need to notch the top of the block?
68formalGT- Posts : 865
Re: A-head 547
Bore the block, it's a bunch of power. And the a460 stuff has plenty of rebuilds left at that bore.
Re: A-head 547
Wow that outta be a Monster with 572 CID and 15:1 CR.
How large of a bore can an A-460 block have, I thought 4.6 was the limit.
Dark Horse of Apocalypse- Posts : 171
Re: A-head 547
. Most of the are safe at 4.625 and a lot of times moreDark Horse of Apocalypse wrote:Wow that outta be a Monster with 572 CID and 15:1 CR.
Re: A-head 547
Boring it that much about killed me. Will it work like this? As for carb I already have it and I think it will make more power than I was after to begin with. Any thought on how much power?
Re: A-head 547
You need pistons and rings either was it's not expensive to go the additional .100 over it's done all the time.
Re: A-head 547
I bored mine 4.640 I hope it lives in know a guy said he has been 4.670 in a pull truck
larry552- Posts : 335
Re: A-head 547
If you have the ser # of the A460 block, call Ford Racing and they should be able to send you the sonic test for your block. (I think)
Re: A-head 547
Really I didn't know you could do that. Another reason why I like this fourm
Re: A-head 547
So block was bored 4.600 15-1 compression pistons intake is the tall trick flow with only port match.
waiting to get motor back, PAR in Spartanburg SC is putting it together
does any body have an opinion on power # ?
Re: A-head 547
motor is finally together, chassie was 4-linked and is finally done, time to put together. What spark plugs to use for a heads in this combo ?
Re: A-head 547
Well tomorrow is the day I finally get to race, I hope. Tried a few weeks back, to many problems never made a full pass. Our home track Greer Dragway is having their big Turkey Trot end of season race. Anyone close should come, weather looks good so there should be alot of cars.
Re: A-head 547
so what did it make on the dyno?
kjett- Posts : 1169
Re: A-head 547
Did not dyno it, wished I would have. Most of the problems that I have had would have been found then. Live and learn I guess.
Re: A-head 547
What did it run? That should be a strong engine.
bigblock t-bird- Posts : 201
Re: A-head 547
4.84 at 140 mph Carb is bad fat at ideal. Ordered a kit today from Holley to rebuild it. The guy at Holley said he thought my jets were to small, so I ordered 4 more. Also my water pump and fan took a dump, so lots to do before next weekend.
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» P-51 Head's /Head Studs/pushrods (SOLD)
» 624 C-head
» 624 C-head
