Ground Pounder K-Member Question
I picked up this Fox Body Ground Pounder K-member on a trade, Is it something that would support that 460? I will be using Front & Mid plates + a solid tranny mount, I want to go with either QA1 or some other type of coil over conversion with tubular A-arms, 5 Lug conversion and Manual steering.
JT460- Posts : 17
Re: Ground Pounder K-Member Question
Its plenty strong I'm sure, but the design of the lower control arm mounts will limit the header clearance to near what a stock k-member has.
Gary
Gary
GTmustang- BBF CONTRIBUTOR
Stay away from the QA1 junk. Strange struts and shocks are the best for the money. That K-member is not the best either. TeamZ has good prices on Strange products.JT460 wrote:I picked up this Fox Body Ground Pounder K-member on a trade, Is it something that would support that 460? I will be using Front & Mid plates + a solid tranny mount, I want to go with either QA1 or some other type of coil over conversion with tubular A-arms, 5 Lug conversion and Manual steering.
Outlaw5.0- Posts : 122
i use the team-z and i like it
bigjohn2007- BBF CONTRIBUTOR
» Ok to put car on ground without center section?
» relay for tb
» Tornado on the ground !!!!!
» Ground rods
» relay for tb
» Ground rods
