heater hose connection leak
GT300TD
heater hose connection leak Empty heater hose connection leak
Post  GT300TD August 17th 2014, 2:21 pm
Noticed a little puddle of coolant on the top of my timing chain cover coming from the 90 degree fitting at the intake manifold (it's not leaking from the hose). Of course I can't tighten it because it hits the fitting and the short hose that goes to the water pump. Is there any way I can stop the leak without taking the water pump or manifold off. I thought about Stop Leak ??? or loosening the 90 degree fitting (can only go about 1/4 turn) and spraying 'something' on the threads and re-tightening it???.
Anyone know any tricks they are willing to share  Question
GT300TD
heater hose connection leak Empty Re: heater hose connection leak
Post  bbf-falcon August 17th 2014, 5:44 pm
Can you cut it off somehow and take it out and replace it w/shorter elbow?
Post  GT300TD August 17th 2014, 9:09 pm
The snout that the heater hose goes on would have to be 3/8" or less to clear the water pump hose.
GT300TD
Post  maverick August 17th 2014, 9:18 pm
Kinda hard to picture this deal. Got a photo?
Post  GT300TD August 17th 2014, 10:11 pm
I backed off the heater hose fitting a little more than a 1/4 turn, the 90 degree fitting snout that the heater hose connects to, the left (90 degree) fitting, hit the 2" (+ or -) hose that connects the water pump to the intake manifold. I measured the distance between the heater hose fitting and the short hose and it was 3/8" between. So if I could cut and remove the left fitting  I would need a 90 degree fitting with a 3/8" or less 'snout' in order to clear the short hose that connects the water pump to the intake manifold to screw it into the intake manifold, wheww.
GT300TD
Post  69F100 August 17th 2014, 11:35 pm
If you look in the chassis tech on my frontend swap on the last page and the last pic are you talking about the little hose in between the pump and intake. I shorten mine it is a pain to get on but with a couple of screw drivers it will go on only about 1\2 of the hose is on each nipple never has leaked so far. I was going to make it longer when i put engine back but forgot to pick up a new peace of hose.
Post  crittersf1 August 18th 2014, 8:00 am
Grease it up real good and it will slide right on.
crittersf1
crittersf1
Post  GT300TD August 18th 2014, 10:26 am
The car is running and driveable, the problem is the 90 degree fitting (that attaches to the heater hose) that is to the left of the short hose that goes from the intake manifold to the water pump is leaking at the intake, and I don't want to remove the intake or water pump to fix it, if possible.
GT300TD
Post  JACKAZZFLATZ August 18th 2014, 3:14 pm
I made a new one outta 1" square aluminun bar. Intersect drilled and tapped for 3/8" NPT. Used a close nipple from manifold to block, and new hose nipple from block to hose. Had just enough room to spin on the new block. It dont look too bad with a scotch brite finish on it........
JACKAZZFLATZ
JACKAZZFLATZ
Post  GT300TD August 18th 2014, 6:36 pm
JACKAZZFLATZ wrote:I made a new one outta 1" square aluminum bar.  Intersect drilled and tapped for 3/8" NPT.  Used a close nipple from manifold to block, and new hose nipple from block to hose.  Had just enough room to spin on the new block.  It dont look too bad with a scotch brite finish on it........
I backed the 90 degree fitting off till it hit the short hose, cleaned the threads at the intake the best I could and put some permatex red thread locker on the 1/2 of thread  Rolling Eyes. Then tightened it as far as I could leaving just enough room under the top hose to the radiator to get my heater hose back on  scratch If that doesn't stop it then I'll try to cut it like Rick said and make a fitting like you did. Or maybe take the water pump off  Question
Thanks guys  Smile .
GT300TD
Post  bbf-falcon August 18th 2014, 9:28 pm
Terry,I just went through this when I switched engines from a BB to a Windsor in a 71 mach. I have some different size elbowed fittings you are more than welcome to try.
Post  GT300TD August 19th 2014, 9:09 am
[quote="bbf-falcon"]Terry,I just went through this when I switched engines from a BB to a Windsor in a 71 mach. I have some different size elbowed fittings you are more than welcome to try.[/quote)
This may really test the strength of the permatex red. If it works maybe I can 'give' some useful info on the Forum for a change  Suspect
haha.
Thanks Rick  Smile
GT300TD
Post  GT300TD August 21st 2014, 2:54 pm
The permatex red seems to be holding, not much run time though.
GT300TD
