who ever made/designed
557 mazda
DanH
frank13
who ever made/designed Empty who ever made/designed
Post  frank13 April 29th 2010, 5:52 pm
the positioning of the header bolts is a freaking moron!
I cant get a damn bolt on every other hole thanks to how tight the tubes are to the header bolt hole.....
now i get to ding up a nice looking set of headers!
i tried different bolts, no help!
i tried socket head bolts, but cant get a tool on it
i tried studs, but cant get a nut on then,,,,,,
taking a little break then to try again with a clear head
frank13
frank13
http://www.frankskinkracing.com
who ever made/designed Empty Re: who ever made/designed
Post  DanH April 29th 2010, 6:08 pm
you have header bolts = 3/8 nc use 7/16 wrench. 3/8 bolt with 9/16 wrench size -- can see why your having trouble
DanH
who ever made/designed Empty heater bolts
Post  557 mazda April 29th 2010, 8:13 pm
They make a header stud 3/8x5/16 so you can use a 3/8 bolt hope that helps...
557 mazda
557 mazda
Post  dfree383 April 29th 2010, 8:20 pm
Put the hard ones first leave them real loose, and take all them in each a turn at a time.
Post  BOSS 429 April 29th 2010, 8:26 pm
ARP MAKES A 3/8 / 5/16 STUD, THEY TAKE LITTLE NUTS, work great
Post  frank13 April 29th 2010, 9:33 pm
DanH wrote:you have header bolts = 3/8 nc use 7/16 wrench. 3/8 bolt with 9/16 wrench size -- can see why your having trouble
http://www.jegs.com/i/Trans%20Dapt/969/8885/10002/-1?CT=999
my local parts guy had these! made life super duper easy! its amazing what you learn in a day.....
frank13
frank13
Post  Larry T April 29th 2010, 9:46 pm
i went to the local nut & bolt store and asked for the exact same bolt but to no avale.im glad you took the time to give us a part number,thanks
Larry T
Larry T
Post  John I. April 29th 2010, 11:07 pm
I have a 7/16ths wrench ground down so you can almost see through it. I put a set of headers on my 1979 F150 a few months ago and wasn't surprised to see nothing has changed since I last put a set on a truck back in the late '70's. Still had to notch the frame to get them in and still had to struggle and cuss. The collectors are better though - they finally figured out the flat triangle flange thing was a FAIL
John I.
Post  bcr466 April 30th 2010, 12:07 am
There is also a bolt that has 3/8 std thread with a 12 pt head to use a 5/16 12 point socket or wrench.
bcr466
bcr466
http://cracing@frontiernet.net
Post  342g April 30th 2010, 7:34 am
I thnk you are talking about the 3/8, twelve point head.
342g
342g
