Cam selection help
Cam selection help Empty Cam selection help
Post  tpndrcn May 16th 2015, 12:24 am
After not being able to identify the cam that came in my motor I have decided to go new,but need help.Here's my setup:
70 1/2 Falcon (same as 70 Torino)
3435 lbs
3.50 rear gear , 28 inch tall drag radials
85 C6 stock
TCI breakaway conetter 2400-2600
69' C9VE 460 block
69 C9VE heads-stock
429 4u crank
413np 429 cast pistons .030 over
434.71 c.i.
4.39 bore
3.59 stroke
9.65 c.r.
Edelbrock Performer intake
2 inch primary headers
stock electronic dist
780 vs carb is the plan
I would like a good street manner cam , with mid range torque so I don't blow the tires off at the track. Looking at hydraulic flat tappet to keep cost down cause this is a budget build!! Or if someone has some used stuff that will work I am open to ideas.
Thanks for the help in advance.
tpndrcn
Cam selection help Empty Re: Cam selection help
Post  dfree383 May 16th 2015, 7:10 am
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1011&sb=2
Or the next smaller one would work good
Lunati offers similar stuff
Post  supervel45 May 16th 2015, 9:58 am
http://www.lunatipower.com/Product.aspx?id=1680&gid=287 This is the Lunati that is close to the Comp 275. The Comp does have more exhaust duration (13* more), and exhaust lift, compared to it's intake lift. If you don't have the best exhaust system or exhaust port flow, the Comp cam may help bandaid it more than the Lunati. If you really want to kill some low end torque, you could go up one or two steps in the Voodoo series. Also remember at over .540-.550" of lift valve seal interference is a problem, and you may have to cut the guides down.
Post  tpndrcn May 16th 2015, 10:41 am
Supervel45 will i be safe not cutting down the guides with the cam you recommended or not then because the lift is right there? Also I have stock rockers with poly locks with they work or am I gonna have to consider rollers?
tpndrcn
Post  supervel45 May 16th 2015, 10:56 am
You don't need roller rockers. You do need to check your guides and seals for clearance.
Post  dfree383 May 16th 2015, 9:43 pm
Make sure to use the recommended springs with the cams too.
Post  supervel45 May 16th 2015, 11:35 pm
http://www.summitracing.com/parts/sum-3501    This is a budget cam with about the same .050" specs. as the other cams mentioned, with .503" lift on a 114 LSA. You won't have to worry about your guides and the cam/lifter kit is $118. It's just another option to consider. PS That .471" lift is a misprint, scroll down the page for the correct specs.
Cam selection help Empty Thanks & Cam Selection Made
Post  RedDragonCobra January 11th 2023, 8:50 am
Thanks for all the help guys. I have finalised on a Lunati Solid lifter cam that I've had to buy from JEGS as both Lunati and CompCams do not accept non US addresses in their systems! Managed to source lifters here in the UK. Can't wait to get the parts so we can get going again.
RedDragonCobra
Post  supervel45 January 11th 2023, 3:50 pm
Did you end up with this one? It was to replace the C460 right?
https://www.jegs.com/i/Lunati/638/30340505/10002/-1
Only 2 of those Lunati mechanical grinds they list.
Anyway glad you found something. Cool
Post  Dave De January 11th 2023, 9:48 pm
Amazing after 8 years you responded. I've never seen that much time interval. Anyway your package is not hard and a Comps 262 would probably work better than that square pattern Summit stick.
Post  supervel45 January 11th 2023, 9:59 pm
I think RedDragonCobra replied to the wrong cam thread. Wink
And that Summit 3501 has changed spec.'s over the years. LoL
