Need cam selection advice
Like the title says I need help selecting a cam. Here's what I have, or will have in the very near future. Car will be an 80/20 street/strip car. Mostly for blowing away the rice-heads, slomaros, and thoses annoying 5.0 cars
D1VE block .060 over
D0OE-R decked an unknown amount
Eagle cast steel crank stock stroke
Eagle ESP H-beam forged rods
Pistons are 12.1cc dished and should net around 11.1:1 CR
Intake is a Weiand Stealth
Carb is a BG 750 Speed Demon (yea, I know it's too small but my pockets are only so deep at the moment)
I also have a 2-stage nitrous that I was going put a total of 100-150hp shot just for special occasions
Trans is a C-6 and is SUPPOSED to have a 3500 stall in it.
Rear gear is currently a 4.10, but I will be dropping to a 3.73 for a little less RPM's on the street.
Car currently has a CompCAms TRUCK cam in it at the moment. I really need some idea on where I should be at with lift and duration. I read somewhere else that nitrous likes a longer duration. 290-310 ????? Can I get away with a .590-625 lift??? Any help in this would be greatly appreciated. I posted on the other place, but didn't seem to get much response.
jonboyusmc- Posts : 71
Re: Need cam selection advice
why the stock stroke eagle crank?
I picked up a killer deal on the rods, pistons, bearings and ARP stud kit. $450, I couldn't pass up because I got it broke off in my a$$ when I bought the motor which was already supposed to be built good. I'm just trying to make some horsepower on a budget. Right now I couldn't even sell the car for what I have in it, unless you want an over-heating POS with 5lbs of oil pressure.
no more than you plan to spray i would'nt worry about a nos cam.is your car a fox mustang?just guessing.
Nope, SN95 Here's a link to some pics in the intro section.
https://www.429-460.com/introduction-f8/hello-from-n-il-t6355.htm
jonboyusmc wrote:I picked up a killer deal on the rods, pistons, bearings and ARP stud kit. $450, I couldn't pass up because I got it broke off in my a$$ when I bought the motor which was already supposed to be built good. I'm just trying to make some horsepower on a budget. Right now I couldn't even sell the car for what I have in it, unless you want an over-heating POS with 5lbs of oil pressure.
If I remember right ... on the other site you claimed this to be a basket case that you got a "good" deal on and were going to take apart and re-do everything anyway.
Looks like you found a 460 crank and some good rods and pistons.
Unless you have TWO engines of the same realm going together.
» cam and intake selection for a 429
» ok truck guys i need advice come on in heros need motor advice also
» Cam selection
» Cam selection help
» Cylinder head selection
» Cam selection
