Cam selection
Cam selection Empty Cam selection
Post  SLord82 December 22nd 2011, 2:58 am
I'm currently in the planning stages of a 547 build for my 71 Torino. I had planned on a solid roller but after all the recent talks about solid flat tappet cams not giving up much if any power to a roller and rollers taking a dump on the street I'm just as lost as ever.
Parts I have collected so far;
forged h-beam 4.5 stroker kit
Ported P51s from C. Evans (~420cfm @ .600)
matching 4500 Victor
110mm SV-1
Comp rockers 1.7 ratio (oops) or HS 1.73 ratio
I also have the 460 I built a few years ago as a starting point. It has a Comp XR280 (or something like that, 242 and 248 @ .050 and .650 and .667 lift, from memory) solid roller with comp lifters. I hadn't planned on reusing the cam because I think its too small, nor do I plan on reusing the lifters because of longevity issues I rather not take a chance on. These lifters were from ~2003-2004 before all the fancy direct oiling for street motors.
I want the motor to be super reliable for mostly street duty and the occasional thrash while still maximizing these great heads. I would like 750hp and 700lb-ft with a table flat curve, which seems reasonable to me with these heads but maybe I'm way off base.
Plan on running pump 93. Stick car with 3.50s out back.
Soooooo, with all that being said should I spend the extra money on a roller or will a healthy flat get me there?
Thoughts on this flat tappet?
http://www.ebay.com/itm/LUNATI-429-460-FORD-290-298-VOODOO-SOLID-CAM-CAMSHAFT-/360360869276?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item53e72e7d9c
What about this roller?
http://www.ebay.com/itm/LUNATI-429-460-FORD-285-293-VOODOO-SOLID-ROLLER-CAM-KIT-/140606720425?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item20bcd049a9
Sorry for the epay links, but I haven't seen that voodoo flat tappet listed anywhere else, even on Lunati's own site.
Custom grind?
Thoughts?
SLord82
Cam selection Empty Re: Cam selection
Post  Tennessee Bullitt December 22nd 2011, 7:03 am
Call Lem up, on my first 521 build he pretty much nailed it for me when be built a solid flat tappet. You won't loose much between a solid roller and a well built solid cam. He can hook you, he sure as hell did for me. cheers
The trick is a custom cam is better than a off the self cam and it will cost you the same. scratch
Tennessee Bullitt
Tennessee Bullitt
Post  quick 52 December 22nd 2011, 6:37 pm
what cam mfr. does Lem use
quick 52
Post  Lem Evans December 22nd 2011, 6:52 pm
CompCams lobes.
Post  SLord82 December 22nd 2011, 8:32 pm
how do the comp lobes compare to lunati and crane and etc?
SLord82
