Correct Flexplate selection
Have a 1970 D0VE 429 and I need to know how I can tell if it should have an internal or externally balanced flex plate.
I have been told somehow I can tell from the crank shaft...
Can anyone advise me for sure
72GTSNCode- Posts : 18
Re: Correct Flexplate selection
The spacer behind the harmonic balancer will have a hatchet shaped weight on it if its externally balanced.
dirtbogger- Posts : 172
All 429's are internal balance, therefore there will not be any balance weights on the flexplate.
Greg_P- Posts : 1009
» Do i have the correct dip stick for my pan?
» 429 Build - Piston questions.
» what is the correct way to weigh a car?
» What is the correct size end?
» Determining the correct valve geometry??
