429 Build - Piston questions.
429 Build - Piston questions. Empty 429 Build - Piston questions.
Post  75truck October 30th 2015, 1:05 pm
Building a 1971 429 block with a 429 crank.  Is the L2366F Speed Pro the correct piston to use for the stock crank to obtain the piston flush with the deck?  Stated compression height is 1.89. Any other suggestions for pistons?
Using heads D3VE_A.
75truck
429 Build - Piston questions. Empty Re: 429 Build - Piston questions.
Post  dfree383 October 30th 2015, 1:27 pm
Not to be a jerk, but I'd suggest getting a 460 crank and your piston options become a lot better and you will gain a noticeable amount of torque.
429 Build - Piston questions. Empty I appreciate the 460 crank comment.
Post  75truck October 30th 2015, 2:00 pm
I guess I'm not so concerned with ultimate torque. Just a 3/4 ton truck that is a weekend driver. I just really want a slightly upgraded 429. I think it to be more unique. I am also considering putting a tbi injection unit on it.
thanx
Bob
75truck
Post  supervel45 October 30th 2015, 2:06 pm
I would skip the forged pistons if it is going to be a naturally aspirated engine.
Post  dfree383 October 30th 2015, 2:15 pm
75truck wrote:I guess I'm not so concerned with ultimate torque.  Just a 3/4 ton truck that is a weekend driver. I just really want a slightly upgraded 429.  I think it to be more unique.   I am also considering putting a tbi injection unit on it.
thanx
Bob
Then your selection for pistons is very limited and you will need to deck the block to get zero deck if that's what your looking for.
429 Build - Piston questions. Empty So is this piston correct?
Post  75truck October 30th 2015, 2:30 pm
Is the L2366F Speed Pro the correct piston? Price seems right around $440 on Sleezepay.
75truck
Post  slurm October 30th 2015, 9:40 pm
Just built a 429 with l2366f and i did have to deck block. Using eagle rods. I dig the 429. Look around someone has to have them setting around.
slurm
slurm
