C6 transmission with a brake drum on the tail,
I know a guy in need of a c6 for a 460 in a motor home. The original c6 is demolished. He bought a rebuilt unit with a normal tail, not realizing it will not fit. I am not sure, but I believe he may be willing to negotiate with the rebuilt unit in exchange for a good unit that will work in the motor home.
Anybody have anything laying around? He is in the Cincinnati area, I think we would do about a 1 hour drive in any direction from Florence Ky.
jpierce55- Posts : 111
Re: C6 transmission with a brake drum on the tail,
I've got a good C6 w/o.d unit and it's own tail shaft. I'm not real familiar w/the ones w/brake drum. Is the main shaft the same?
I am pretty sure the main shaft is not, just due to what I am looking at on the brake. This C6 is shorter than the one he bought. It is weird, and I have never seen one like it before. I am guessing it is something for the big trucks/motorhomes/etc.
I have the transmission that is ready to go,
Has less than 40 passes on it since the last refreshing.
It has a frank merk trans brake in it and a billet forward drum, it is roller bearings and new clutches, and
a lot more. It ran low 9 secs with my 572 big block. If you are interested contact me.
67460- Posts : 384
It comes with your choice of converters, a 9.5 or a 8 inch.
67460- Posts : 384
» Need help IDing Ford Brake drum
» WANTED 1970 mustang drum brake spindles - got them
» Does adding a wave plate help the forward drum last after trans brake installation
» Nut on reverse brake band adjuster leaking - C6 transmission
» Question regarding SFI bellhousing for auto transmission, and Automatic Transmission Flexplate Shield
