How Small of an Engine or Bore Would the A-460 Heads Be Recommended?
How Small of an Engine or Bore Would the A-460 Heads Be Recommended? Empty How Small of an Engine or Bore Would the A-460 Heads Be Recommended?
Post  Dark Horse of Apocalypse August 29th 2014, 5:00 pm
Would you use A-460 heads on a Tunnel Rammed 468 CID(Std Bore +.040) with 13:1 Cr for a Bracket Car or a 528 cid Pump Gas street machine which needs torque to pull a heavy Pro-Street Lincoln?
How Small of an Engine or Bore Would the A-460 Heads Be Recommended? Empty Re: How Small of an Engine or Bore Would the A-460 Heads Be Recommended?
Post  DanH August 29th 2014, 5:50 pm
i'd use the A head for that type of build, but then also use
DanH
Post  dfree383 August 29th 2014, 6:04 pm
With a 2.300 valve I'd run them on the .030 or .040 stock bore.
I'd avoid the TFS tunnel ram and use a Motorsport single 4 on the small engine. Also watch the port sizes on the smaller inch engine it's real easy to make a pig out of a small one with way to big of heads.
As far as a street drive 528 in a big ass Lincoln, I'd be more inclined to use a P-51 or a SCJ, unless your not worried about how fast it really is.
Post  bbf-falcon August 29th 2014, 10:07 pm
Yep,bigger isn't always better in some cases. Shocked
