Street Head Mafia "reload".......
+16
gmsmkr
butterbean
D. Sea
Dave C.
70FB
10SHOTS
Dark Horse of Apocalypse
mstngfreak
SandHillsHillbilly
20 posters
Page 1 of 2
Page 1 of 2 • 1, 2
this is a build Im doin for a buddy, I aquired my old TFS "street" heads back for this project. Ill get some pics and videos when this thing goes to the dyno. This is going in a fox and will serve dual duty as a 235 radial plate class as well as a grudge car setup.
A460 block, 4.530 bore
Lunati forged 4.5 crank
Scatt H beams w 2000 bolt upgrade
custom Diamond pistons, 13.5-1
TFS Street heads, chambers have been softned for nitrous use
custom ground Comp Cam
Morel lifter, Comp rockers
Trend pushrods, Jomar stud girdle
Ford Racing billet chain set
Kasse oil pump, Moroso pan
IW balancer w CT magnets
heavily ported victor jr inatke
quckfuel 4150 1050 cfm carb w annular boosters
Cometic head gaskets.
will use an Induction solution Real Street plate set up
will use both the 4150 and a 4500 carb for the dyno pulls.
updates will follow....
Re: Street Head Mafia "reload".......
Excuse my ignorance I was borne in TN, but what do you mean by softening the chambers?
Sounds like a beast for sure!
mstngfreak- Posts : 10
SandHillsHillbilly wrote:Excuse my ignorance I was borne in TN, but what do you mean by softening the chambers?
Smooth & polish. Sharp points and rough surfaces are an invitation for potential dynamic disassembly (blow stuff up).
BTW, "dynamic disassembly" and "it came unmanufactured" are 2 of my favorite terms.
maverick- BBF CONTRIBUTOR
How "ported" are the intake ports if the vic jr has had a bunch of work? Is it normal to open them up to CJ size?
jasonf- BBF CONTRIBUTOR
Sounds like a keeper should look and cook.
Dark Horse of Apocalypse- Posts : 171
maverick wrote:SandHillsHillbilly wrote:Excuse my ignorance I was borne in TN, but what do you mean by softening the chambers?
Thanks that is what I thought he meant but I wanted to make sure.
I will have to remember those terms, just in case.
These are my old heads and intake, Charlie ported the heads and did some work on the intake, it was already cj sized when he got both.
Just asking but why annular boosters in the 1050 ?
10SHOTS- Posts : 587
thats what it came with lol
I suspect it's because the carb is a 4150 style 1050 which would make the thing ~ a straight gut....not much of venturi effect.
I missed the 4150 1050 part , thanks
need lifters
Update....
Almost ready for the runstand.....
I'm digging the dipped valve covers. Looks good.
70FB- BBF CONTRIBUTOR
I gotta quit drinking.
Dave C.- Posts : 1268
Not dipped those are the real deal
Looking Good...what kind of N/A dyno numbers are you thinking it will make?
FalconEh- Posts : 1448
res0rli9- BBF CONTRIBUTOR
I will say 780 with the 4500.
Looks good!
D. Sea- Posts : 2768
even better!richter69 wrote:Not dipped those are the real deal
Not sure it will get dynoed, would make mid 800s or so would be my guess.
is this the engine going into the Cougar???
butterbean- Posts : 676
Page 1 of 2 • 1, 2
» mafia intake and tfs street alum heads
» A head street build
» 529" TFS street head build.
» TFS CNC Street cylinder head performance
» Mercruiser Shim Head Gasket OK for Budget Street Use?
Page 1 of 2
