A head street build
A head street build Empty A head street build
Post  litshoot February 20th 2019, 3:12 pm
Im looking for a solid street motor and have a set of old a heads laying around, how would they be, and is it possible to set them up in 4.4, or 4.44 bore, 3.59 stroke, flat tops to get roughly 10,5 compression to run 92, hydraulic flat tappet cam. theyre 2.3 intake 1.88 exhaust, 63cc chambers. Would this work, what kind of power could be expected with tfs tunnel ram, single dominator.
litshoot
A head street build Empty Re: A head street build
Post  BBFTorino February 21st 2019, 12:00 am
Why the short stroke?
Post  dfree383 February 21st 2019, 5:48 am
Youre really miss matching everything
What you’ve described would run better with a set of ported Dove-c castings and an old fashioned Weiand TR and a set of 750’s
Post  stanger68 February 21st 2019, 1:23 pm
dfree383 wrote:Youre really miss matching everything
Tunnel ram??? On a street engine? That’s your first choice?... really
Post  litshoot February 21st 2019, 1:27 pm
Short stroke, for no real good reason, I have a 429 crank and a 460 crank, but 429 looks a little better condition.
litshoot
Post  strongweapon March 7th 2019, 11:11 am
I like it.
My setup is close. Offset ground 3.59 crank to 3.71 with iron A460 heads. (EX514). TFS Tunnel Ram and carbs???
I have Mighty Demon 850s and King Demon 1095s.
The heads are at the shop for bowl blending and port work. Should be ready in a few weeks.
Just enough OVERKILL!
strongweapon
Post  litshoot March 7th 2019, 11:21 am
just realized my mistake in the begging, not a tunnel ram, a460 single plane with single dominator flange. my fault. also its what I have, its matched set to each other.
strongweapon, no kill like overkill
litshoot
