Rear disk brake kit for big bearing 9in
AndyLeslie
NO FAIR
tconnection
Rear disk brake kit for big bearing 9in Empty Rear disk brake kit for big bearing 9in
Post  tconnection September 7th 2014, 5:02 pm
Let me know what u got. If I can afford it ill buy it.
Last edited by tconnection on September 9th 2014, 10:16 pm; edited 1 time in total
tconnection
Rear disk brake kit for big bearing 9in Empty Re: Rear disk brake kit for big bearing 9in
Post  NO FAIR September 7th 2014, 6:32 pm
Try Quick performance that's where I got my stuff great customer service.
Dave
Smile
NO FAIR
NO FAIR
Post  AndyLeslie September 7th 2014, 7:28 pm
Stumbled across this by accident, later model Explorer rear disc brakes, brackets and everthing bolt right up to late model big bearing Ford 9 inch ends, with 2.5 offset axles. Super cheap rear disc conversation.
AndyLeslie
AndyLeslie
Post  tconnection September 7th 2014, 11:23 pm
About what year explore. You know ford got some high tech explorers out here now days.
tconnection
Post  AndyLeslie September 7th 2014, 11:28 pm
I think, 1998 to 02ish, and possibly a little later. I will have to look at my notes in the shop tomorrow.
AndyLeslie
AndyLeslie
Post  tconnection September 7th 2014, 11:56 pm
Ok, I went to ebay and found some info. 1995-01 but it looks like the bracket deal has to go on before the bearings. Ild have to press mine off but the bracket may can be notched.What do you think?
tconnection
Post  AndyLeslie September 8th 2014, 12:06 am
I don't see why you couldn't notch the bottom of the bracket and slip them over.
AndyLeslie
AndyLeslie
Rear disk brake kit for big bearing 9in Empty rear brake conversion
Post  bowsher21 September 8th 2014, 9:16 am
This might help,
http://www.jalopyjournal.com/forum/threads/9-inch-rear-disc-brake-installation.569272/
bowsher21
bowsher21
Post  dfree383 September 8th 2014, 10:21 am
You sure you have big bearing stuff? Or is it the Torino bearing?
From my understanding the 8.8 stuff is all Torino bearing?
Post  tconnection September 8th 2014, 2:01 pm
Its a M9 housing. I just posted some pics in proven build. I never checked the dia. of the bearings.
tconnection
Post  dfree383 September 8th 2014, 5:48 pm
"Big" bearing is generally Lincoln or Full size stuff, not typically used in aftermarket.
Post  AndyLeslie September 8th 2014, 7:21 pm
The explorer brackets, bolted right up to strange ends. Don't know what to tell ya.
AndyLeslie
AndyLeslie
Post  tconnection September 10th 2014, 10:35 pm
Two more ? about these brackets. Did you use the rotors and calipers off the explorer rearend? Would the oem rotor fit on after market axles?
Thanks again
tconnection
Post  69F100 September 10th 2014, 11:16 pm
tconnection wrote:Two more ? about these brackets. Did you use the rotors and calipers off the explorer rearend? Would the oem rotor fit on after market axles?
Thanks again
My old set up I had on my Ranger was off a late 90s model Linc. Town Car with the 8.8 I had to do some mods to the brackets the hole would not line up but would have if I had the small bearing 9'' that hold the calipers but the rest fit right on my axles they are Moser and my rear end is a big bearings rear out of a 74 f150 that had 31 spline axles
Post  DanH September 11th 2014, 6:45 am
dfree383 wrote:"Big" bearing is generally Lincoln or Full size stuff, not typically used in aftermarket.
The BIG Linclon bearing size is the most common for aftermarket race brakes
DanH
Post  dfree383 September 11th 2014, 12:48 pm
I've seen mostly Torino stuff not Lincoln. But hey I've been wrong before.
Post  DanH September 12th 2014, 4:45 am
best way is to spec the OD of the axle bearing . Big Lincoln/Olds ends are 3.150" od. Later Ford big bearing housing ends have a different bolt size and pattern. Ssmall axle bearings are are commonly called Mustang or Fairlane be it 9" or 8" axles
DanH
Post  tconnection September 13th 2014, 11:36 pm
Andyleslie, does this bracket suppose to hold the axle in? I mean does it suppose to fit up against or around the bearing?
tconnection
Post  tconnection September 15th 2014, 10:33 pm
I finally got this explorer rear disc brake thing together. Thanks for putting up with me. Im bout done with this car.
tconnection
