BG 400 fuel pump
Tech @ BG
63boxtop
BG 400 fuel pump
mine took a crap for the 2nd time in 5 years, last time i sent it to them and the rebuilt for about $150, are they still in business or did they file for bankrupcy, i thought i saw a discussion on them a while ago
rick
rick
63boxtop- Posts : 64
Re: BG 400 fuel pump
the BG rep is on here from time to time i will foward this to him and see if we can get a responce
Still here repairing pumps as usual. With all the complaining on some of the boards regarding the amount we were charging we went back and looked at what our competitors charge and found we were a lot cheaper on some of the parts as we have not adjusted them in 15 years or better. There will be a price increase coming on some of the parts as a result of this so the sooner you get it in the better. Same procedure as before and right now they are trying to turn everything around in 7 business days or less once it hits the door.63boxtop wrote:mine took a crap for the 2nd time in 5 years, last time i sent it to them and the rebuilt for about $150, are they still in business or did they file for bankrupcy, i thought i saw a discussion on them a while ago
rick
Tech @ BG- Posts : 28
So how much is a rebuild?
Depending on what it needs right now the prices are set at 125.00 for a full bottom end rebuild and 54.00 for a motor. If it does not need everything then it will be less depending on what parts are actually needed.richter69 wrote:So how much is a rebuild?
thats not bad , mine will be heading your way via ups tomorrow
rick
rick
Repair it your self, o-ring sets are only 12.00 bucks, easy fix.
342g- BBF CONTRIBUTOR
its actually a motor problem so basically i get a new pump for $175, not sure if its my set up or just these pumps but the same exact thing happened about 5 years ago and they hooked me up in no time at all
rick
rick
63boxtop wrote:its actually a motor problem so basically i get a new pump for $175, not sure if its my set up or just these pumps but the same exact thing happened about 5 years ago and they hooked me up in no time at all
rick
So is 5 years the typical lifespan for one of these pumps? I ask because the noisy old blue pump has been in my Pinto since the 80's.
jasonf- BBF CONTRIBUTOR
jasonf wrote:63boxtop wrote:its actually a motor problem so basically i get a new pump for $175, not sure if its my set up or just these pumps but the same exact thing happened about 5 years ago and they hooked me up in no time at all
rick
my old blue pumps have been running since 1977, I keep a lower rebuild kit just in case... But all I ever did to it was take it apart and clean it out and make sure the screan was clear.....
the Coug- Posts : 3055
he had said that my input and out put lines wern't big enough but i'm using -10 on both sides so who knows
rick
rick
There are plenty of guys out there with them that have used them for longer then 5 years but like everything else no two situations will be the same. If you have been using a blue for 20+ years and it has not been repaired then consider yourself lucky.jasonf wrote:63boxtop wrote:its actually a motor problem so basically i get a new pump for $175, not sure if its my set up or just these pumps but the same exact thing happened about 5 years ago and they hooked me up in no time at all
rick
A -10an inlet line will cause cavitation over time and damage the pump.63boxtop wrote:he had said that my input and out put lines wern't big enough but i'm using -10 on both sides so who knows
rick
Basically that would be the case if it needed everything. If not then you are only charged for the parts that it does need.63boxtop wrote:its actually a motor problem so basically i get a new pump for $175, not sure if its my set up or just these pumps but the same exact thing happened about 5 years ago and they hooked me up in no time at all
rick
I have been running the BG 400 now for over 10 years. I have to say that they were the first guys to build a good single high volume pump for racing. However I think they have been surpassed in the last few years by the magna fuel and others. Still a decent pump but not the industry leader they once were.
As for rebuilding yourself yes the bottom O-ring is easy, I found that out when the last rebuild I got back from BG did not even have one. Went down to my industrial supply store and bought 2 spares for a couple of bucks. The top seal on the motor shaft however seems to be propietary... at least I havent been able to find a replacement yet. I have had the seal fail,,, start to leak gas 3 or 4 times now over the years. In a pinch I take the pump apart smear silicone grease on the seal and put it back together, works for a little while but doesnt last. Only problem I ever had with the motor was a bad bearing, easy fix standard skf bearing easy to replace.
Other issue is the cheesy adjustable bypass assembly. I tried adjusting, I tried shims, I tried several times but I could never get the thing to create enough back pressure to create the 28-30 lb pressure at the pump they claim it can make. Finally I just plugged it and went to a return line system with a QFT regulator at the front of the car.
This is just my experience, I realize this is probably the most common pump in use today and works very well in a lot of situations. In fact I still use it, just carry a hot spare.
Currently running rear mounted pump,-12 suction line, -10 to front reg, -10 return to the rear mounted tank, feeds a 900hp, A460 head Super Gas car best et 8.31 @ 165.
dkp
dkp
bosshoss- BBF CONTRIBUTOR
bosshoss wrote:I have been running the BG 400 now for over 10 years. I have to say that they were the first guys to build a good single high volume pump for racing. However I think they have been surpassed in the last few years by the magna fuel and others. Still a decent pump but not the industry leader they once were.
There is a company that sells the o-rings, I have bought them a few times, I will see if I can find the web-site.
dkp
guess i'll upgrade my inlet to a -12 and see iff that gets me some more life out of it
rick
rick
» Do I need to remove my already intalled fuel pump eccentric if I'm now going to be using an electric fuel pump?
» BG 400 fuel pump help
» what fuel pump to run
» Magna Fuel Prostar seal
» Fuel pump
» Fuel pump
