welding balance weights
+11
bbfstanger
bosshoss
Rmk Boss9
Dark Horse of Apocalypse
kim
DanH
rmk57
15 posters
welding balance weights - Page 2 Empty Re: welding balance weights
Post  rmk57 September 18th 2014, 10:11 pm
I'm going to contact the shop and see what they can do for me. If they say nothing, then I'll do some name dropping.
rmk57
Post  FalconEh September 18th 2014, 10:13 pm
Post  rmcomprandy September 18th 2014, 11:47 pm
Rmk Boss9 wrote:
kim wrote:Looks like a decent weld.  So aside from the fact that its a little back yard.   Through 6500 shouldn't be an issue.  Once the pans on no-one knows if you have Mona Lisa or velvet elvis under the cover.
The weld on the other side is a better looking, flatter with more penetration from what I can see.
I'm going to go ahead an run it.
The balance was a flat rate cost, plus the price of the Mallory. I would have gladly paid an extra $100 and have it done right instead of this f#uck up.
"RIGHT" is a matter of opinion.  There is nothing mechanically wrong with how that is done except that  it doesn't look pretty.
Just as I replied to you on the other site.
EDIT:  Next time be sure to mention that you need it to look pretty, also. Then it can all get filled-in with weld and it can be ground pretty ... at the further expense of "time and material".
Last edited by rmcomprandy on September 18th 2014, 11:55 pm; edited 3 times in total
Post  FalconEh September 18th 2014, 11:50 pm
With this response I retact my previous comment, as he Definately knows more about the functionality of that picture than I Do Embarassed
Post  FalconEh September 19th 2014, 12:00 am
Get what you ask for...and pay for.
Post  Rmk Boss9 September 19th 2014, 12:14 am
It's definitely a time saver! Maybe they should all be does this way. I wanted it done like the other 99% of the shops do, that's all.
Rmk Boss9
Post  kjett September 19th 2014, 7:21 am
x2 on what Randy said. I'm no pro, but I do spend massive amounts of time in my engine builders shop and do some of the balance jobs that come through (got to pay my machine shop bills homehow!). Sometimes the crank needs weight added where there really isnt an area to add weight. There are tricks where you remove or add in other areas to try to get the balance to move to add/remove weight back where there is material. Looking that this is on the very edge of a throw, this may have been the case. Since this was a "flat rate" job, if this was a small shop, time is money so they did the job to make it mechanically correct and not have an excessive amount of time wasted to make it "pretty".
kjett
kjett
Post  bbf-falcon September 19th 2014, 8:32 am
I also agree with Randy,ive seen some cranks and other parts back in the day that would scare you to death,but they did the job.
Post  rmcomprandy September 19th 2014, 10:06 am
bbf-falcon wrote:I also agree with Randy,ive seen some cranks and other parts back in the day that would scare you to death,but they did the job.
Years ago, we would get a piece of mallory and drill a 7/16 hole through the middle. Then drill and tap the side of the crankshaft counterweight and bolt the weight in place.
Realistically, that was more unsightly but, those all worked just fine. It takes a bunch of deteriorating circumstances to break an alloy rod bolt and the weight attached to those is a whole lot more.
Post  Paul Kane September 19th 2014, 11:28 am
rmk57 wrote:I've never seen a crank balanced like this before and would some expert opinions on using this up to 6500 rpm.  It's a 4.15 cast Scat crank.
If it's correctly balanced and that's where the weight was needed then it's perfectly fine for your appplication and a complete non-issue.
Which parts (piston/rod) were used for the rest of the rotating assembly, and exactly how old is the crankshaft?
Post  Curt September 19th 2014, 6:35 pm
And to add, it's a cast crank. You probably won't be reselling it if used for racing purposes.
Post  Rmk Boss9 September 19th 2014, 7:17 pm
The crank was brand new.
Scat I-beam rods and SRP -28cc pistons.
I'm probably going to go ahead and use it as is. It just isn't what you expect to see when you unpack your new crankshaft.
Rmk Boss9
Post  rmk57 September 19th 2014, 8:14 pm
welding balance weights - Page 2 IMG_14081024x683
welding balance weights - Page 2 IMG_1409683x1024
The other weld which looks prettier than the other one and a copy of the balance card.
rmk57
Post  kim September 19th 2014, 9:56 pm
cranks get welded on all the time. One of the ways to repair a journal... weld, and turn back down. Original offset stuff,, add weld and move center.. Back in the stone age of this sport, China didn't cast one of every stroke out there. People remanufactured what was available.
We would weld in the Mallory slugs in the throughs..
kim
Post  dfree383 September 20th 2014, 12:13 am
To be fair i have seen a lot uglier work
Some major Swiss cheese drilling and I do recall a mopar crank once with nuts welded to it in a number of places......
Post  6t6mustang September 29th 2014, 6:44 pm
I would not put that in any engine with my name on it.. "if" it comes off, it will do major damage to a lot of stuff, I won't even let a balance shop end press weight (radially).. also, that is mig welded, tungsten to cast with er70.... nope. No
6t6mustang
6t6mustang
