1st Pass With New Gear Box
https://www.youtube.com/watch?v=90_CXK1Ay4s
Had a great 1st pass, full pull, still need a lower ratio to get my rpm back to were I used to run with dot tires.. Does any one know how many rpm are gained by each point in ratio changed, Im at 23-1 now , thinking maybe 25-1,
samiam- Posts : 240
Re: 1st Pass With New Gear Box
4lo.com has a great gear ratio calculator.
schmitty- Posts : 4538
grimmjeeper also
http://www.grimmjeeper.com/gears.html
from 23.25 to a 24.26 at 29mph it changes the RPMS from 6663 RPM to 6953 RPM
23.25 to a 24.94 at 29mph it changes to 7148rpms. so I'd say around a 425-500rpm jump
Last edited by 460pulling on September 22nd 2014, 10:55 am; edited 1 time in total (Reason for editing : added info)
460pulling- Posts : 249
Thanks for the info guy's, found a set of 2.55- 1 gears, should put me right at 71-7200
samiam- Posts : 240
» Radiators.....Single pass or Dual Pass, which is better?
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
