Header dilemma....... Mine don't fit !!
+6
10 posters
Guys,
Do any of you know if the Hooker, D&D, Kooks, etc... all route the tubes the same way?
I have a set of headers that are supposed to be for a BBF in a Fox chassis, but they don't want to cooperate. I can't find any markings on them other than a part number of 7113 and what appears to be a date code of 9 01 .....
These things just don't seem like they will work at all. I looked a friends Mustang this evening. He's got a BBF in it with the Hooker headers AND engine mounts and what looks to be the same k-member. Comparing the headers I have to his the forward tubes on mine do not sweep back far enough to clear the engine mounts and all of my driver's side tubes are tucked tight together almost as if they are designed to go between the steering shaft and block. Two of the Hooker's tubes go outside of the steering shaft...
It appears I got hosed on a set of headers.... Got any clues?????????
jbozzelle- Posts : 3705
Re: Header dilemma....... Mine don't fit !!
The Hooker headers are PN# 6224. Two tubes on each side are slip fit.
I had big time fit issues with mine.
Bill
Bill
billandlori- Posts : 2081
It seems the headers you have are made to be used with a front motor-plate. There are no side mounts at all with a front motor-plate.
It's called refabricate.
I have had three different sets on my car over the years. The front motor plate saved the day on every set. I had to move the engine everytime I changed headers, just moved the plate mount.
Not a bad deal , just something that had to be done.
If I were to buy a set of headers for a non-factory swap type deal, I'd buy them without any plating or ceramic coating. That way they can be cut and modified for a CORRECT fit if necessary, then ceramic coated later. These days, though, I'd rather just custom build a set.
maverick- BBF CONTRIBUTOR
Have no idea how that double post happened............
Parkinson's?
IDT-572 wrote:I have had three different sets on my car over the years. The front motor plate saved the day on every set. I had to move the engine everytime I changed headers, just moved the plate mount.
I could see that. Being that there are several different plates out there plus they are custom mounted anyways it would be pretty a pretty slim chance that the motor would be in the same place every time.
jasonf- BBF CONTRIBUTOR
Sorry for the late reply. I haven't been getting reply notifications.
I was hoping someone recognized the part number. I'm planning to get after it this weekend. Gonna prop up the engine plate with jackstands and remove the mounts. Just hoping I don't sawzall off the k-member mounts just to find out it still doesn't fit. That'll piss me off!!
What's strange is all of the driver's tubes are bent to go between the engine and steering shaft. The tubes are mandrel bent as well. Not cut sections welded together. That's why I'm thinking these are not for this engine/chassis combo...
John,
You'll find that if/when you cut off the engine mounts to the K-member, you will open up a TON more room!
Use the engine plates, cut the engine mount pads on the K-member and modify the headers to fit or make a new set. Got any pictures you can post?
Good luck
Good luck
D. Sea- Posts : 2768
For those of you that have never met Blake, He also STUTTERSIDT-572 wrote: Have no idea how that double post happened............
This is the exact reason I put a post on this site a week ago about asking if a set of headers for a 1990's f250 with a 460 working on a fox swap. You can buy the truck headers for $200 and a set of fox swap headers are $500 and some need modified. Why not modify the cheap headers.
tiger- Posts : 272
bbf-falcon wrote:For those of you that have never met Blake, He also STUTTERSIDT-572 wrote: Have no idea how that double post happened............
Rick your so stu stu stu stupid................ Leave me alone.
Driver's side fits.
Pics later...
Pics later...
jbozzelle wrote:Driver's side fits.
Pics later...
You're half way there... Nothing to this stuff
Nevs- BBF CONTRIBUTOR
Header tubes pass directly where the k-member mounts are. Once I chopped them off they fit fine.
Pics will be in my thread in the Proven Builds section. I'll throw them up shortly. Just got in from the garage....
tiger wrote:This is the exact reason I put a post on this site a week ago about asking if a set of headers for a 1990's f250 with a 460 working on a fox swap. You can buy the truck headers for $200 and a set of fox swap headers are $500 and some need modified. Why not modify the cheap headers.
If you're gonna apply logic, you ain't gonna fit in around here. jk.
Jbozelle, glad it worked out well for you.
Tiger, I haven't had to cut these headers at all. Just had to remove the mounts and perches from the k-member. Thes eheaders are obviously made to work with plates, front and rear. One tube is modified from the previous owner because he used these in a tube car I believe...
Guys, I've got new pics up in the PROVEN BUILDS section.
» 9" 3.062 vs. 3.250-Minor Dilemma-Opinions Wanted
» Trans tailshaft to pinion alignment dilemma.....
» Best Electric Water pump
» Check your intakes!
» Got some
» Got some
