cal-trac set up on a mud truck.
Anybody ever run a cal-trac set up on a mud truck ? I'm kicking around idea's on traction aids for my leaf spring truck that I can do over the winter.
i
i
mudtrucker- Posts : 160
Re: cal-trac set up on a mud truck.
After spending alot of time figuring them out on my f100 (asphalt drag) I cant see them transfering any weight in your application due to the 4x4s ride height. Id bet theyd certainly help plant the rear tires though lol.
dirt_worker- Posts : 535
Myron "Mud Freak" on 460Ford.com ran them for a while. I believe he had pretty good luck with them. He has videos on YouTube, I think under Hillbilly Rockstar. Yellow 70's 250 or 350 that he eventually put on a half ton frame and stepside box without fenders.
68formalGT- Posts : 865
More of a swamper than a wheeler, but if you are going to use track bars on the rears, would it be plausable to limit the front travel so you don`t just yank and drop the fronts, instead find the travel they like and keep them planted
FalconEh- Posts : 1448
» cal-trac set up on a mud truck.
» trac-loc question
» Cal Trac Question
» true- trac
» 28 spline trac-lock
» trac-loc question
» Cal Trac Question
» true- trac
