how about mounting a 1356 t-case Clocked at a different position??
clocking a 1356 t-case??? rotate it a couple holes??? it would put the front drive shaft below the cross member... anyone every try this?
racinghabbit- Posts : 575
Re: how about mounting a 1356 t-case Clocked at a different position??
To do that you would have to do away with the alignment pin, if it's a manual shift, fab up new linkage, and you will be adding another angle to your driveshaft,, most cases are clocked to get the shaft as straight as possible ,,, what are you trying to accomplish ?
samiam- Posts : 240
Doesn't the BW1356 have an internal oil pump?
aquartlow- Posts : 167
aquartlow wrote:Doesn't the BW1356 have an internal oil pump?
Yes it does.
nord315- Posts : 28
» 1356 t case leak
» T-19 and 1356 F/S
» 1993 F250 4x4, D60, 460/E4OD/1356
» New position at work
» Rotor position
» T-19 and 1356 F/S
» Rotor position
