Rebuild info
Vinnybigblock
Page 2 of 2 Previous  1, 2
Rebuild info - Page 2 Empty build
Post  butterbean November 16th 2014, 1:55 pm
well said Falcon, to the OP, do you wanna make 600/550 N/A or with boost or NOS? and do you want to do this with pump gas or race gas? its easier to get those numbers with high compression and race gas, but do you have E-85 where you live? is that a option? anyway like others have said stroke is your friend, and you can get stroker kits kinda cheap these days and if you are not racing it a cast crank will do, good luck with your build
butterbean
butterbean
Rebuild info - Page 2 Empty Re: Rebuild info
Post  Vinnybigblock November 17th 2014, 9:14 pm
E85 is plentiful where I live. I did find a master rebuild kit that came with forged pitons. I'd like to make 600hp all motor. I hope this can be achieved through the right cam/intake/head work/exhaust/tune on the factory compression. This is the engine that was 375hp factory. Is has 74cc chambers.
Vinnybigblock
Post  dfree383 November 18th 2014, 12:17 am
375 hp eungine where 429 SCJ's not the regular 460's.
You're going to need some really good head porting work to get that kind of real power.
Post  Vinnybigblock November 18th 2014, 12:33 am
This was the pre smog 460 out of a lincoln mark 3. They were rated at 375...
Vinnybigblock
Post  Vinnybigblock November 18th 2014, 12:36 am
I'm sorry it's 365 hp. ......
http://en.m.wikipedia.org/wiki/Lincoln_Continental_Mark_III
Vinnybigblock
