freeze plug tap
+13
Gregaust
YellowStangDuane
Beltfeed
manofmerc
jones
gt350hr
butterbean
fordguy69
gmsmkr
17 posters
freeze plug tap Empty freeze plug tap
Post  gmsmkr November 23rd 2014, 7:53 pm
What size tap do I need for the freeze plug holes on a d1 block ?
I keeping hearing about freeze plugs coming out on some peoples blocks and I don't want that to happen to me any help would be great.
gmsmkr
gmsmkr
freeze plug tap Empty Re: freeze plug tap
Post  fordguy69 November 23rd 2014, 10:07 pm
1 1/4-11 1/2 NPT pipe tap
I bought a couple on ebay. Got some nice HSS ones in the $30 range.
fordguy69
Post  dfree383 November 24th 2014, 12:55 am
I've never had a freeze plug come out.
Post  butterbean November 24th 2014, 12:45 pm
I was thinking about doing this too, after talking to XolieX affraid
butterbean
butterbean
Post  gt350hr November 24th 2014, 3:02 pm
I'm doing it too. Already have the plugs and tap. D9TE block but who cares? Never need replacing and never leak.
gt350hr
Post  jones November 24th 2014, 4:55 pm
Most of the times I have ever seen a plug blow out was from a cracked block or blown head gasket pressurizing the cooling system. if I'm not mistaken the screw-in freeze plugs where used to strengthen the block.
I apply anaerobic sealant to the plugs before setting them in the block and then paint over them when I paint the block.
If I remember correctly, you will need to find a straight tap as well as a tapered tap. If you can't find a straight tap you will have to cut one of the tapered tap's in half. I don't think you will have enough depth to run a tapered tap in enough.
jones
Post  IDT-572 November 24th 2014, 5:32 pm
You need two tapered taps one with almost have cut off. the reason is to be able to tap the hole and let the plug get almost flush when tightened.
The un cut tap will start and tap, but bottom out against the cylinder wall before taping deep enough to allow the plug to engage deep enough. Then use the cut off tap to go on deeper.
Post  jones November 24th 2014, 5:58 pm
IDT-572 wrote:You need two tapered taps on with almost have cut off. the reason is to be able to tap the hole and let the plug get almost flush when tightened.
What he said!! Very Happy
jones
Post  fordguy69 November 24th 2014, 9:50 pm
I didn't need to shorten a tap. Regular NPT tap has plenty of room in a big block. In fact, one block I did went a little too deep and had to buy some oversize plugs.
Small block on the other hand, you need to shorten a tap to get them deep enough.
fordguy69
Post  FalconEh November 24th 2014, 10:08 pm
For those who may have a freeze situation ie: Up North with a non heated shop/garage you may want to do 7-screw in plugs with a block heater in one of the easy to access holes, one based off of a regular freeze plug not one that bolts in, or do all eight and remove some or all for the winter.
Last edited by FalconEh on November 24th 2014, 10:13 pm; edited 1 time in total (Reason for editing : more info)
Post  gmsmkr November 24th 2014, 11:23 pm
dfree383 wrote:I've never had a freeze plug come out.
I haven't yet but I hear a lot of guys are popping them out going down the track with solid mounts.
I have run many combos with out the screw in plugs but it seems to be getting very common lately and nobody has a explanation for why or how so I'm just a little scared of it happening to me.
Thanks for all the help on this guys study
gmsmkr
gmsmkr
Post  FalconEh November 25th 2014, 12:13 am
I can say learning the nitrous curve I have ventilated a few head gaskets, and popped a freeze plug or two, I have also had a thermostat failure (when I ran one) popped a plug, and once upon a time left water in my engine in a non heated garage and popped a freeze plug, probably all were a Savior for the blocks, the screw in plug definitely helps to keep everything together when you are hot lapping it in the ladder rounds and the cooling system needs help, because with a push in plug you may find yourself missing a plug and deciding how much you want to risk to go the next round less coolant and very hot....but remember when you eliminate the weak link you create a new one... bom Remember to deal with the cause of the question.
freeze plug tap Empty Freeze plug popping
Post  manofmerc November 25th 2014, 6:16 am
I popped a freeze plug at the track one night .Luckily nothing bad happened .After that incident I went with a 10 pound radiator cap .No more problems .I had been running a 16 pound cap .Screw in plugs are naturally a much better solution .Doug
manofmerc
Post  Beltfeed November 25th 2014, 9:10 pm
IDT-572 wrote:You need two tapered taps one with almost have cut off. the reason is to be able to tap the hole and let the plug get almost flush when tightened.
Yes and no. What I did was tap all the soft plug holes with a standard length  pipe tap. Then cut about 1/2" off the end in a wet abrasive cutoff saw. Now I have a tap to run back in the pre tapped holes and size them for the tapered plugs. You can buy Stainless or aluminum 1-1/4" pipe plugs from McMastercarr online. This is a one block only way of doing it. If you do another block you will need to buy a second tap.
Beltfeed
Post  IDT-572 November 25th 2014, 10:37 pm
Exactly what I ment...........
Post  YellowStangDuane November 25th 2014, 11:37 pm
I've never had a plug come out, but don't want to chance it. Current engine has screw in plugs, and the one on the stand will get them. I did not have to cut my tap, or use another.
YellowStangDuane
YellowStangDuane
Post  Gregaust November 27th 2014, 6:54 am
So you guys tapping these freehand or setting block in a mill or similar ??
Gregaust
Post  fordguy69 November 27th 2014, 9:47 am
Gregaust wrote:So you guys tapping these freehand or setting  block in a mill or  similar ??
I did mine freehand. The cast taps fairly easily. I used a framing square to make sure I got the tap started in square to the opening and let 'er rip.
fordguy69
Post  Gregaust November 28th 2014, 5:43 am
Nice work Thanks
Gregaust
Post  Doug Rahn November 28th 2014, 7:00 am
I know I'm getting old Laughing  but I believe I've posted this up before, maybe a different Forum. An engine has two 'cooling system pressure zones' called block pressure and system pressure. We're all familiar with the system pressure which is dictated by the radiator cap (usually 15-24 PSI). The block pressure is dictated by the water pump's output and can exceed 80 PSI at high RPM (depending on where the reading is taken). The engine block's water jackets act like a manifold, flowing coolant (under full pressure of the water pump) to the head gasket orifices for uniform distribution. On some engines, the pressure zone begins to change here. (Ever notice how small the head gasket coolant holes are in engines like the small block Chevy?) The coolant flows through the cylinder heads and intake manifold, then it is subjected to a 'pressure drop' caused by the thermostat restriction (open or closed).
A mechanical high output water pump is capable of 180 GPMs and very high 'block pressures'. This is what blows out core plugs at high RPM. Using a high flow thermostat, a functioning bypass hose and not running your cold engine (thermostat closed) at high RPM is advantageous.
Also don't forget to take into account the area of a plug which is about 1.77 sq. inches, so the pressure pushing on it is probably around 140 lbs. Core plugs are also a stamped sheet metal part and are not what I would call a precision part. Manufacturers dies do wear and who knows how often they replace them, diameters could vary wildly  Twisted Evil .
Post  bbf-falcon November 28th 2014, 10:25 am
In all the years of racing and street machines, I've never had issues with properly installed pop in plugs.
Post  maverick November 28th 2014, 11:03 am
bbf-falcon wrote:In all the years of racing and street machines, I've never had issues with properly installed pop in plugs.
Me either....but now I'm scared to drive my racecar. affraid
Post  DFI429 November 28th 2014, 3:03 pm
Paranoia.
I think Doug Rahn might be the only poster in this thread to correctly refer to them as CORE plugs... Freezing has nothing to do with their intent/purpose.  Not a surprise with manufacturing being run out of this country.. Mad
While there may be a structural benefit to threaded core plugs, they simply aren't a fail safe for poor coolant mixture by the owner Wink
DFI429
DFI429
Post  bbf-falcon November 28th 2014, 4:38 pm
DFI429 wrote:Paranoia.
I think the most of us know in fact that they are CORE plugs,but we still sometimes call them "Freeze" plugs as habbit. Smile
Post  YellowStangDuane November 28th 2014, 6:44 pm
I've never lost one, but I have gotten to the track, then noticed one was leaking.... That sucked.
YellowStangDuane
YellowStangDuane
