Freeze plug question
83-88T-Bird Guy
Gregaust
OldRedFord
What size are the freeze plugs for the factory production block?
How many of the threaded plugs withe the hex head should be in the kit? There are five in the kit I got. Where do the two that are pointed at the back go?
OldRedFord- Posts : 465
Re: Freeze plug question
Are the brass plugs 1 1/2" ?
The pointed plugs are the ones in the front behind the timing gear
Gregaust- Posts : 625
read this it will help you on the the plugs on the front of the motor if you don't get them right the oil pressor want be right
http://www.460ford.com/forum/showthread.php?t=139162&highlight=oil+resticter+plug
if your interested in screw in freeze plugs, here is an article:
https://2img.net/h/i273.photobucket.com/albums/jj226/carmagguy/ThreadingforCoreplugsTech1.jpg
https://2img.net/h/i273.photobucket.com/albums/jj226/carmagguy/ThreadingforCoreplugsTech2.jpg[b]
83-88T-Bird Guy- Posts : 1003
1 1/2 is what my brass freeze plugs were.
tiger- Posts : 272
tiger wrote:1 1/2 is what my brass freeze plugs were.
If you are going to tap them for pipe plugs, they are as Lem stated, 1.25 NPT. They may measure 1 1/2", but that isn't pipe thread sizing.
Nevs- BBF CONTRIBUTOR
Sorry didn't see he wanted screw in.
tiger- Posts : 272
ALL Ford engines of the era use 1-1/2" freeze plugs.OldRedFord wrote:What size are the freeze plugs for the factory production block?
The number of oil gallery plugs depends on the size of plug we re talking about.OldRedFord wrote:How many of the threaded plugs withe the hex head should be in the kit? There are five in the kit I got. Where do the two that are pointed at the back go?
» Freeze Plug
» freeze plug tap
» freeze plug kit install
» Do they make a screw in freeze plug kit for stock blocks
» 474CJ freeze-up
» freeze plug tap
» 474CJ freeze-up
