SINGLE PLANE DUAL QUAD INTAKE ??
gt350hr
dragsterdick
Wayne Pearce
Hey guy's: I was wondering if any single plane dual quad intakes were ever developed for the big block Ford? Would there be any benefit over a dual plane (such as a Blue Thunder), or tunnel ram dual quad intake? Just wondering - Happy Thanksgiving to all, don't eat, or drink too much - but eat, and drink enough!
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
460 Single plane
I run a BT Dual plane on my Galaxie NSS car because there are no good single planes out there for sale. It works great and hopefully better with a little trick told to me to do by the carb spacer guys. Won't know till spring though? Happy Thanks giving to you and everyone as well!!
dragsterdick- Posts : 54
Re: SINGLE PLANE DUAL QUAD INTAKE ??
I have a Blue Thunder dual quad setup on my 30 Model A coupe, and haven't driven it yet, but it should be a lot more street friendly than the tunnel ram that was on it before. But I was curious as to why there's no performance single plane dual quad setups available that I could run on my 545 50 Ford Coupe? I'm presently running an 1150 SV1 on a Edelbrock Victor intake, and don't want to poke a tunnel ram through the hood.
Wayne
Wayne
Single plane
Wayne, Sounds like you have a couple of really cool cars!! Any pics cause they must be great? I think the reason there are no good single plane dual quad intakes for the 460 is because there is not enough demand? Would be mostly used on a car like mine and most guys use an FE motor. I wish there was a good one to buy.
With the availability of big dominators the 2x4 low stuff is pretty much a nostalgic thing IMO. And not much demand.
Wayne,
According to the SK parts log book I have there was a prototype single plane intake developed in '69 for Nascar use. Ford downsized the 429 wedge to 366 for potential use so maniflods were made. In the 45 years I have been chasing experimental Ford parts , I have yet to see one. This is despite finding many one and two of a kind prototype parts. The Blue Thunder dual plane was developed about the same time ( originally with an SK number) and is more common. My guess is a handful were made and they were less powerful than the dual plane or had fuel distribution problems and were scrapped. Several single plane single four "spider" ( as they were called at Ford) intakes were made as well all carrying SK numbers. I think there is one on epay now.
gt350hr- Posts : 662
Why no (good) single plane dual quad intakes? Because Procomp. With that POS they released last year, it's unlikely anyone will put the money into development of a quality alternative.....unless I win the lotto.
Best option at this point would be to use the lower half of a Weiand tunnel ram and make your own carb adapter. Still kind of tall, but not much taller than a Victor or Mafia intake.
You could also build your own with a mig welder, some sheet metal, and some exhaust tubing bends. Hardest part would be finding somebody to make some flanges, and that wouldn't be very hard.
Carl- Posts : 284
Carl wrote:Why no (good) single plane dual quad intakes? Because Procomp. With that POS they released last year, it's unlikely anyone will put the money into development of a quality alternative.....unless I win the lotto.
Do you know anybody who's actually run/tested one of the Pro Comp intakes?
DaveMcLain- Posts : 399
Last edited by JBR-3 on February 22nd 2020, 2:09 am; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
JBR-3 wrote:This is an idea, just an idea for now, but one I will eventually pursue.
I have two Victors that I want to cut up to make one 2x4 single plane.
Save the center four runners with the carb pad on each manifold, then
figure a way to weld them together.
This isn't the only way to do this. For example, you could take one Victor
and "hollow it out", cut out all the runners and, presto, there's your new
base piece. Add runners and carb mounts as desired. Poor man's exotica.
Just remember that the runners are not spaced the same as the bore spacing of the engine.
Do you have proven evidence that it's a pos or just your personal assumption?
» Tunnel Rams for the Street??
» Dual Quads on a 460
» dual plane intake for 557
» Question: Blue Thunder 2x4 intake
» Low rise dual quad intake??
