think i hurt the motor part 2
think i hurt the motor part 2 Empty think i hurt the motor part 2
Post  muddog899 November 29th 2014, 10:49 pm
Ok life finally got out of the way and I could do a compression test and a leak down test on the motor.
Here are the numbers that I came up with all do the compression numbers first followed by the leak done numbers,
Cyl 1 137 5%
Cyl 2 155 8% air in to valve cover
Cyl 3 145 5%
Cyl 4 150 8%
Cyl 5 140 5% air in to valve cover
Cyl 6 130 5% air into valve cover
Cyl 7 140 5%
Cyl 8 145 2%
The numbers don’t look the best but not bad either I figured that my compression numbers should have been better. What should I be looking for when I start to tear it down.
muddog899
think i hurt the motor part 2 Empty Re: think i hurt the motor part 2
Post  Frank Merkl November 29th 2014, 11:19 pm
When in doubt tear it down !! If every thing looks good , nice clean smooth cylinder walls - put a new set of rings in it WITHOUT honing as the last set of rings just trued up the cylinder walls , put new rings in - the leak numbers will drop in half . I've done it many times . and I was pretty skeptical the first time I was told to do this by RMRE
Post  butterbean November 30th 2014, 5:05 pm
X-2 and I would also check valve guides for play, and hand lap the valves in too
Last edited by butterbean on November 30th 2014, 5:06 pm; edited 1 time in total (Reason for editing : added)
butterbean
butterbean
Post  the Coug November 30th 2014, 7:17 pm
butterbean wrote:X-2 and I would also check valve guides for play, and hand lap the valves in too
if you have someone that knows what they are doing you don't have to hand lap valves
Post  butterbean November 30th 2014, 7:43 pm
my machinist lives in the trailer park so I always lap them in
butterbean
butterbean
