O-Ring BBF Block For Nitrous
gmsmkr
O-Ring BBF Block For Nitrous  Empty O-Ring BBF Block For Nitrous
Post  FalconEh December 5th 2014, 9:57 pm
Thoughts on installing O-Rings in the BBF block (10-bolt) for Nitrous application, at least 1 DP kit +?, is it worth it on the BBF and if so any recommendations.
O-Ring BBF Block For Nitrous  Empty Re: O-Ring BBF Block For Nitrous
Post  gmsmkr December 5th 2014, 10:35 pm
This is just my op but a set of mls gaskets will do just fine
gmsmkr
gmsmkr
Post  FalconEh December 6th 2014, 12:23 am
Cool Thanks M, I agree I have pushed the small blocks but I hate having the head gaskets ventilate and need to remove and deck, especially if I go with an aftermarket block, the two I have here will probably burn up LOL ...I want to build a third BBF having never running any of them.
Post  richter69 December 9th 2014, 12:25 am
just cometics here with 500 plus of spray ..... no water in the overflow ever
Post  FalconEh December 9th 2014, 12:32 am
Nuf Said...Delete
Post  bruno December 9th 2014, 9:58 am
had an o-ring block with copper gaskets , nothing but problems ...... went to a cometic with a smooth ra and never had an issue
http://WWW.CKRME.COM
Post  richter69 December 9th 2014, 9:10 pm
And dont kill it with timing.
Post  FalconEh December 9th 2014, 10:13 pm
bruno wrote:had an o-ring block with copper gaskets , nothing but problems ...... went to a cometic with a smooth ra and never had an issue
I was a little surprised that the o-ring process consists of file fitting copper or stainless wire, as opposed to having a 360* (not 358*-359*) CNC'd or water jetted ring tapered and driven in...maybe something to look into Rolling Eyes
richter69 wrote:And dont kill it with timing.
I resemble that comment Lol...been there done that, used the old old school methods to compensate and burned up some stuff cyclops I think a 7531 will be in order, I tend to start with less timing and creep up on it now. Laughing
Post  cool40 December 9th 2014, 11:13 pm
O-rings and copper gaskets work well together if you don't run water! Lol.... cherry
Post  gmsmkr December 9th 2014, 11:55 pm
You mean your supposed to run water with this kind of stuff Razz
gmsmkr
gmsmkr
Post  kim December 10th 2014, 12:05 am
You can run water, you just drain it once done playing. 7 PSI cap helps cut down on the leaking too. Ive got stainless steel insert ring in the block, .033" thick copper gasket from SCE and receiver groves in the heads. All water passages had a .030 or so RTV smear that had all but set up before the head was set on the block.
kim
