o-ring block
tconnection
o-ring block Empty o-ring block
Post  tconnection November 11th 2010, 2:20 pm
What's good and what's bad about o-ringing a block for copper head gaskets? Its
The machine shop that im dealing with said it'ld be best and can handle lots of nos and high boosts.
tconnection
o-ring block Empty Re: o-ring block
Post  cool40 November 11th 2010, 2:49 pm
unless your gona have a lot of nos or blown you should stay away from o-ring's.i did mine and it has always leaked somewhere.i've used a lot of other ideas about how to install them and none have worked 100% as far as leaks go.you can reuse them and get any thickness but i think you can also do that with the newer MLS too.i know some who use the MLS with a lot of nos with no issues. Smile
Post  tconnection November 11th 2010, 2:58 pm
For sure i want be spraying alot of nos but i want it tuff and ready for atleast a 200 shot.
Which MLS is good but dont cost a ton?
tconnection
Post  cool40 November 11th 2010, 10:22 pm
tconnection wrote:For sure i want be spraying alot of nos but i want it tuff and ready for atleast a 200 shot.
good aint cheap and cheap aint good! Laughing MLS are good but will work for you.is this a street build?i'd use a felpro if i was'nt gona hit it with more than 400 shot. Smile
Post  tconnection November 15th 2010, 1:05 pm
This is an all out drag motor. 557, a460, 839/780 lift 14:1 cr. 114 lsa 283/304 @ .050. Im most likely gonna see if i can trade in the fms/1028's, pay the differance and get some MLS's and nip it in the bud.
This cam, the rpm range is like 5000 to 8500 with the ICL being straight up at 114 ICL. Now if i put the ICL at 108, would'nt that make the cam timing events happen sooner and bring the rpm range down? I guess what im asking is that can this 114 LSA cam be made to respond like a NA cam?
tconnection
Post  cool40 November 15th 2010, 8:28 pm
i'm no cam god but i'd think you'd want more lift on the ex.and if you have valve clearance you can advance the cam and bring it in sooner.if you're moving it more than 4*you should get another cam IMO.give Lem a call,he can hook you up with a cam that'll get you where you want to be. Smile
Post  tconnection November 15th 2010, 11:16 pm
Oh yea, Lem had the cam ground and double pinned for my combo. Its a whole heep of cam for me, i think. I just dont want it to be to lazy off da line. C-6, 3:73, 28'' tire. Lem told me all about this cam and what it should be like with my set up but not about setting it up on a 108 or 110 ICL. There's no advance cut into this cam.
tconnection
Post  cool40 November 15th 2010, 11:59 pm
did you tell Lem you were gona spray it? it's hard to have the best of both worlds,n/a and nos.i'd put it in on 110 and check v/c.with a c6,2.46 low gear,it wont be lazy.
Post  Lem Evans November 16th 2010, 12:15 am
Put the cam in at 112*.
Post  BOSS 429 November 16th 2010, 12:33 am
for a 200 shot you sure dont need o rings, 1028 s will be fine
Post  cool40 November 16th 2010, 1:35 am
Lem Evans wrote:Put the cam in at 112*.
Very Happy where's my early x-mas at? Laughing
Post  fatal addiction November 16th 2010, 4:20 pm
i run the mls gaskets with a 250 shot and 16.5to1 comp and havent had any problems...
fatal addiction
fatal addiction
Post  whatbumper November 16th 2010, 5:36 pm
Go MLS. You will need to machine the block properly for them though.
