TFS mafia vacuum leak
Has anyone ever had a problem with this intake not having a flat gasket surface or milled on the wrong angle or just are sealing issues with it at all ? This problem is on the driver side only , when the intake is removed you can see that the gasket is not being compressed at the top of the port and I checked for the leak with brake cleaner .
10SHOTS- Posts : 587
Re: TFS mafia vacuum leak
Put a straight edge on it and an angle finder.
Got the intake milled today , the new bungs that was welded on the intake drawd the port you could see it well at the top of the ports after the first cut .
10SHOTS wrote:Got the intake milled today , the new bungs that was welded on the intake drawd the port you could see it well at the top of the ports after the first cut .
Thanks. I was curious about this.
cletus66- Posts : 865
Installed the intake last night and the problem is fixed
Is this a common problem after having fogger nozzles installed? Is this due to improper welding technique? Maybe should have been done a little slower w/ a tig?
460bronco- Posts : 364
