Thoughts !
Thoughts !
Thoughts, on my chitty picture/ drawing of a NOS line routing for a solenoid back up keep in mind this is only intended for the nitrous side of life, this setup consists of 2-qtr turn valves, #1 is the main NOS solenoid, #2 is the safety / bypass solenoid, and #3 is the purge valve solenoid. If #3 solenoid fails flip off the power switch purge valve is dead, if stuck open turn off #2 switch, if #1 fails, leave #3 off and #2 activated
Last edited by FalconEh on February 12th 2015, 10:28 pm; edited 1 time in total (Reason for editing : pic)
FalconEh- Posts : 1448
Re: Thoughts !
What you gonna do if the fuel noid sticks
gmsmkr- Posts : 1364
Re: Thoughts !
gmsmkr wrote:What you gonna do if the fuel noid sticks
Wait for the track staff to return my intake and hood
Re: Thoughts !
just put a 1/4 turn man valve where its easy to get to in a hurry, no need for additional solenoids etc.
Re: Thoughts !
richter69 wrote:just put a 1/4 turn man valve where its easy to get to in a hurry, no need for additional solenoids etc.
I get that is the way it is done, usually the way I do it too, but I like the second solenoid redundancy idea, as the chances of having 2-solenoids fail simultaneously is like winning the power ball, but if 1-fails you don`t even know it failed until you test it ...the round is not lost and the solenoid / lines and wiring might be a 1/4-1/2 lb of added weight with a full round of insurance...both valves are open when it counts...both easily accessible.
Re: Thoughts !
Just use a quality noid w a screened fitting.... The extra noid is just adding more issues imo.
Re: Thoughts !
richter69 wrote:Just use a quality noid w a screened fitting.... The extra noid is just adding more issues imo.
Thanks Richter,
Makes sense... I am guessing that you use a better quality noid than the typical purge kits come with, that is the weak link in my mind.
The wheel works I will leave it alone.
At least I don't use the nitrous setup on this link... anymore
http://www.hotrod.com/how-to/engine/hrdp-1105-leaf-blower-supercharger/
» thoughts on this 99 sd v10?
» Well that wasnt fun
» 572 thoughts??
» your thoughts on e85
» I'm sick of this getting old!
» 572 thoughts??
