572 thoughts??
pigs521bbf
572 thoughts?? Empty 572 thoughts??
Post  pigs521bbf February 15th 2019, 11:45 pm
Has Anyone ever done a 572 with iron heads? Iron heads are only allowed in the class. The use is truck pulling
pigs521bbf
572 thoughts?? Empty Re: 572 thoughts??
Post  rmcomprandy February 16th 2019, 12:15 am
pigs521bbf wrote:Has Anyone ever done a 572 with iron heads? Iron heads are only allowed in the class. The use is truck pulling
The cast iron EX514 heads are used on larger engines than that, even.
Post  pigs521bbf February 16th 2019, 12:46 am
What about with ported CJ heads?
pigs521bbf
Post  DaveMcLain February 16th 2019, 10:31 am
pigs521bbf wrote:What about with ported CJ heads?
Why not?
DaveMcLain
Post  jeffgfg February 16th 2019, 10:37 am
I believe that Eliminator Products makes iron heads that are better that the CJ's.....
jeffgfg
Post  pigs521bbf February 16th 2019, 10:45 am
I’ve just never seen 572 with iron CJs. I have CJs done and ready. Eliminator does make a great head
pigs521bbf
Post  dfree383 February 16th 2019, 11:17 am
pigs521bbf wrote:I’ve just never seen 572 with iron CJs. I have CJs done and ready. Eliminator does make a great head
Youre not looking real hard
Post  pigs521bbf February 16th 2019, 11:22 am
Probably not..
pigs521bbf
Post  TommyK February 16th 2019, 2:03 pm
Brett Powell made around 900 hp at only 470 C.I. with well worked iron CJ's spinning it 8500 ish rpm. I recall another 557 build that made over 800 at a much lower rpm. Can't recall the owner's name but if you search the "other" forum you'll find it.
TommyK
