thoughts on 514
johndickjr
thoughts on 514
have a lead on a decent 514...the crank is a factory offset grind..4.140 stroke...rods are eagle beams..pistons are ross flat tops...what are you guys opinion on this motor ..stuff is used buy has been checked by shop...
johndickjr- Posts : 896
Re: thoughts on 514
H beams?
If you know the history, its been checked out by a reputable shop and priced right.... Go for it.
Re: thoughts on 514
dfree383 wrote:H beams?
X2...
Re: thoughts on 514
I agree with dfree and Randy. If the parts are in good shape and inspected, and the price is right....all should be OK for the 514 in the right application.
The stroked O.E. cast crank 512-514 deals were the heritage for all of the current larger strokers that we all enjoy now. The cranks do not last forever, but not too many of them do.....
Good luck!
Keith
Good luck!
Keith
Re: thoughts on 514
i got chicken..price was way low..275.00..had 2 different h beam rods in it...just seemed to weird so i decide to pass on it
Re: thoughts on 514
for $250 you should have grabed it....... could part it out and make a buck.
Re: thoughts on 514
the pistons were worth that!
Re: thoughts on 514
he said he was building a stock motor..i asked him why not use the 514 stuff he said i dont want that much power..and it had 6 rods with 7/16 bolts and 2 with 3/8 bolts from eagle...just not for me
Re: thoughts on 514
Is this $275.00 price for real...? If someone was to throw all the other parts away, the machined block is still worth that if it's not broken or cracked; jeesh.
Re: thoughts on 514
I think you made a smart move, especially if your time is worth anything. By the time you get it all sorted out, transport it, figure out what you have and go to the trouble of advertising and trying to move the stuff, you're going to be way farther into it than 250.00 worth of your time...if you get your money back.
JMO.
JMO.
Scott Foxwell- Posts : 419
» thoughts on this 99 sd v10?
» Well that wasnt fun
» 572 thoughts??
» your thoughts on e85
» Thoughts !
» 572 thoughts??
» Thoughts !
