from 112 c to108 center line
gt350hr
tconnection
Page 1 of 2
Page 1 of 2 • 1, 2
Aheaded, 14:1cr Motor. Going from 112 center to 108 center line.
About what he increase would there be, if any?
tconnection- Posts : 866
Re: from 112 c to108 center line
How big is the engine and what's the balance of the cam specs? Rest of the combo & whatcha doing with it?
580 ci, the cam is 839/780 114ls, drag only. I gotta check on @.050 and adv.
Not the right move IMO
Not even 110?
I'm all ears and I ain't hard headed.
Curt- Posts : 2791
what you need to do is get this combo done and running and run it like you stole it and quit changing things every week... you will never know how good it runs unless you run it and try to get it tuned out...I am not picking on you just the facts...
the Coug- Posts : 3055
tconnection wrote:Not even 110?
Nope.... I'd head the other way depending in the lobes and rest of the combo.
I'm nor questioning u but this kind of stuff is new to me and I'm trying to pick up on it. Why not go down with cl In this case?
If I hear you correctly...you have a cam that is ground on 114* lsa?
What's the duration at .050"
Compression gearing and weight of the vehicle com into play also.
I'm not going to say it's wrong until I hear more. But in all fairness 580 inches and 108 very seldom go together.
Lem, the cam @.050 is283/302 and at .020 is 316/340.
Yes it's one that you spec'ed and made for me.
I remember you telling me a long time ago to go on 112. Right now I was just wondering what would things be like if it was on 108 or 110. Would it make more hp or what.
Car 3000lb, right now 4:30 pro gear cause its new and was already in the third but figure it with a 3:80 or so. Cr I figuring 13.5. I wanted more. The 91 cc heads were shaved .020 and the dome pistons have a 12.5 cc volume and comp. height is 1.235, 6.8 rod, 4.530 bore, 4.5 stroke. About what will cr be?
tconnection wrote:Lem, the cam @.050 is283/302 and at .020 is 316/340.
I remember you telling me a long time ago to go on 112. Right now I was just wondering what would things be like if it was on 108 or 110. Would it make more he or what.
Have u ran it yet?
No more than down the street.
Yea your right. Its just that I got a couple talkers around here that can't stand me having this setup. And they'really bout to make me mad. But u know, ain't worried cause there's a new Aheaded Beast in town.
tconnection wrote:Yea your right. Its just that I got a couple talkers around here that can't stand me having this setup. And they'really bout to make me mad. But u know, ain't worried cause there's a new Aheaded Beast in town.
F 'em ....carry on.
If you going to be running Douglas track if they hadn't done anything to help traction you going to have your hands full making a full pass. I heard that it is under new management but haven't been there to see how the track is now. But if it is the same as it was like I said you will have full making a full out pass.
The cam is on the money...............
Are you sure your dome is 12.5 cc's If it is I'm seeing about 14.3:1 compression if your chambers are at 85-86cc's
Yea, they have a 12.5cc dome. They are diamond lateral gas ports.
Last edited by tconnection on February 20th 2015, 12:30 pm; edited 1 time in total
Never in my life have i let people not in the know decide if my combo is right or not.
Carry it to the track and wear that bitch out.
Page 1 of 2 • 1, 2
» MSD 6AL, line lock, tranny dipsitck, carb fuel line
» 540 powerboat mill
» What is the weak line in the drive line ?
» Good C6 Line Pressure at 1000 rpm? And more... Stacked shift, Line pressure not changing at different vac levels
» Dual Quads on a 460
Page 1 of 2
