from 112 c to108 center line
gt350hr
tconnection
Page 2 of 2
Page 2 of 2 • 1, 2
Re: from 112 c to108 center line
tconnection wrote:Not even 110?
I'm all ears and I ain't hard headed.
Your original statement "looked" like you were asking about changing lobe seperation ( on the cam lobes)from 112 down to 108 and that would be a mistake in everyone's eyes . Now it seems you are only asking about the amount of advance to run on a 114*lsa cam. "To me" the amount of advance that is correct for your application is what ever makes the lowest ET without hurting the MPH. 6*s advance is on the extreme side ( most often it's 2-4) BUT if your car combination likes it that is what you need to run. Just watch intake piston to valve clearance as it will be less by around .028-.030. 69F100 is right , that much advance could make so much bottom end power the track can't handle it.
gt350hr- Posts : 662
No, I wasn't talking about changing lsa which I don't think can be done. I ment IC.
Im just basically researching and studying.
Thanks for all the info.
tconnection- Posts : 866
Page 2 of 2 • 1, 2
» MSD 6AL, line lock, tranny dipsitck, carb fuel line
» 540 powerboat mill
» What is the weak line in the drive line ?
» Good C6 Line Pressure at 1000 rpm? And more... Stacked shift, Line pressure not changing at different vac levels
» Dual Quads on a 460
Page 2 of 2
