Small block chevy?????
plowboy34
racnrick
OK, correct me if I'm wrong, but how can they call it a small block chevy, when to me, the water pump holes, the exhaust ports and bolt pattern, look to me like a bbc? Even the width of the China wall and the height and width of the heads look bbc.
http://www.dragzine.com/news/cfe-develops-600-cubic-inch-small-block-engine/
racnrick- Posts : 462
Re: Small block chevy?????
They said it's the "Next Generation Small Block Chevy" .....
plowboy34- Posts : 223
racnrick wrote:OK, correct me if I'm wrong, but how can they call it a small block chevy, when to me, the water pump holes, the exhaust ports and bolt pattern, look to me like a bbc? Even the width of the China wall and the height and width of the heads look bbc.
when did Chevy ever have equal bore spacing on the intake runners?
Oh yes when they coppied ford...
blown86hallet- Posts : 1012
Even the timing cover bolt pattern looks like a bbc.
Its a rat with mouse main bearings.
.. Actually its not even a rat with the cam height its a Merlin aka mercury marine with small block main journals.
kim- Posts : 700
It's no more SBC that the nascar stuff..... Purely a race engine that somebody has put a bow tie in the valve covers.
blown86hallet wrote:racnrick wrote:OK, correct me if I'm wrong, but how can they call it a small block chevy, when to me, the water pump holes, the exhaust ports and bolt pattern, look to me like a bbc? Even the width of the China wall and the height and width of the heads look bbc.
The splayed valve, symetrical "Bow Tie" heads have been available since the late 80's. They were most used on the NHRA Pro Stock Truck engines of the mid 90's. It was no FORD copy; the standard 5 head-bolt, 17 bolt pattern of the small block Chevrolet would fit on any production small block engine with the same head gaskets.
» 30's Fords and Small Block Chevy's
» New 57 Ford Project Should we go big block or small block? Pics added
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» distributer block hole is too small on an A460 block
» small block BLOCK choices
