please help COUG!
+9
D's557BBF
13 posters
please help COUG!
Is this real?? Everything I read about the 289 K code engine says "parts weren't marked with an K". That you have to open up the motor to see the true K code things.
Well I came across this intake last night and the guy says it's an K code 289 intake manifold. Ok guys fire away!
Notice the K under the casting letter B
D's557BBF- Posts : 1186
Re: please help COUG!
I'll check the 289 4bbl manifold my dad has to see if it says anything different.
jbozzelle- Posts : 3705
good for 10,000 rpm....
richter69 wrote:good for 10,000 rpm....
Jon I think you may have one that looks like that
No they aren't
C30E-9425-C is for 63-64 hipo
C40E-9425-B is for 64-65 hipo
C50E-9425-A
only K on the manifold I see came on J code cars I saw one on a cougar but no hipos
C50E-9425-A
the Coug- Posts : 3055
This is what I found, and that the only ones that had a special aluminum high rise intake came in the Shelby GT 350's.
"The HP came with a perfectly ordinary cast iron 4V intake - the exact same one used on the plain old 4V engine".
Denaro that being a C8 that is no way a hipo intake in 68 they went from 289 to 302 and I don't remember any 302 Hipos until the 302 Boss
the Coug wrote:Denaro that being a C8 that is no way a hipo intake in 68 they went from 289 to 302 and I don't remember any 302 Hipos until the 302 Boss
I agree.
The 1968 mustangs.....the 2 barrel engines were 289 and the 4 barrel engines were 302.
K code was the engine number in the vin that denoted hipo 289, no k in the engine castings.
Special parts in the 271 hp hipo engines
Block with thicker caps
Hardness tested crank
External counterweight (like external D9 460 hatchet)
Bigger rod bolts (same rods where used on later boss 302)
Heads with cast in spring cups and screw in studs
Heavier springs and a solid lifter cam.
High flow exhaust manifolds.
Dual point distributor
The 306 hp Shelby engines cam with a hotter cam, aluminum intake, tri y headers and a Holley carb.
Their where also some made with 2x4s, webers and even a Paxton supercharged version
I could be missing some stuff but thats what I have from memory
I had a 64 fairlane w/271 hipo, engine had all the things Dave mentioned but I don't remember it having a hatchet, just a wide/thick balancer.
FWIW I have to agree with the comments, but although part number rarity (value) is not there, as I recall all of the 4-bbl intake manifolds were all cast the same, there were no improvements made to the 289 Hi-po intakes (same casting different part#).
Last edited by FalconEh on March 10th 2015, 8:47 pm; edited 1 time in total (Reason for editing : spelling)
FalconEh- Posts : 1448
i would think a c8 intake like that would be a little harder to find.the Coug wrote:Denaro that being a C8 that is no way a hipo intake in 68 they went from 289 to 302 and I don't remember any 302 Hipos until the 302 Boss
bbf-falcon wrote:I had a 64 fairlane w/271 hipo, engine had all the things Dave mentioned but I don't remember it having a hatchet, just a wide/thick balancer.
the 306hp Shelby had a weight , but inside the timing cover.
DanH- Posts : 1081
Thanks guys for all the comments. I was just wondering were in the hell that "K" on the intake came from!!!
Oh well....
Oh well....
Another interesting side note about the cylinder heads is they did not have pushrod guide plates. Ford used close-tolerance slots in the head castings to guide the pushrods.
DanH wrote:bbf-falcon wrote:I had a 64 fairlane w/271 hipo, engine had all the things Dave mentioned but I don't remember it having a hatchet, just a wide/thick balancer.
So did the 271hp
