bulkhead block?
gmsmkr
bulkhead block? Empty bulkhead block?
Post  gmsmkr March 11th 2015, 9:22 pm
Hey guys is there another way to tell if a dove block is bulkhead if it does not have the A on the square pad?
Did they make a bulkhead block that was 2 bolt main?
I know these are sorta dumb questions but really can't find any info on them or I'm just not looking in the right place.
gmsmkr
gmsmkr
bulkhead block? Empty Re: bulkhead block?
Post  dfree383 March 11th 2015, 9:31 pm
I've had a couple boss bulkhead blocks over the years all where 2 bolt and I didn't see anything special on the markings over the regular DOVE-A stuff
Post  bbf-falcon March 11th 2015, 10:47 pm
dfree383 wrote:I've had a couple boss bulkhead blocks over the years all where 2 bolt and I didn't see anything special on the markings over the regular DOVE-A stuff
I've had 2 also,both were Boss bulkhead 2bolts w/A on front left of block.
Post  c.evans March 11th 2015, 11:57 pm
Whether or not the "A" is there in the square pad, it can still be a Boss bulkhead block. The thing to look for that is always there,,,, is under the passenger side lifter galley there will be another bulge that is machined off flat, in the area where they would have drilled the passageway for the dedicated oil galley. In other words the same area that has the dedicated oil passageway for the Boss 429 blocks and the A-460 blocks.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  bbf-falcon March 12th 2015, 12:21 am
http://www.460ford.com/forum/showthread.php?t=161937&highlight=Boss+bulkhead+explained
Post  gmsmkr March 12th 2015, 8:55 am
Thanks for all the help now I know what to look for......
gmsmkr
gmsmkr
Post  Paul Kane March 12th 2015, 12:44 pm
The link provided above goes to a thread that includes pictures, but the pictures may not be viewable if you are not a member of that particular forum and logged in.  The link I provided below is to the same explanation but the images are viewable to anyone who looks at it.
http://www.network54.com/Forum/85220/thread/1351873406
Just providing an alternative for those who cannot see the pictures.
Post  bruno March 12th 2015, 12:59 pm
Thank you Paul, great informative write up.
http://WWW.CKRME.COM
Post  Super Snake Steve March 13th 2015, 10:59 am
Don't now how common it is but I have the boss bulk head and factory 4 bolt main it came out of a 71 Torino Assembled in Atlanta Ga.
Super Snake Steve
Post  DaveMcLain March 13th 2015, 11:47 am
Super Snake Steve wrote:Don't now how common it is but I have the boss bulk head and factory 4 bolt main it came out of a 71 Torino Assembled in Atlanta Ga.
From what I've seen having the "Boss 9" bulkheads or not has nothing what so ever to do with weather or not the block came with 4 bolt caps from the factory it is purely random.
DaveMcLain
Post  Super Snake Steve March 13th 2015, 11:55 am
Would you say they were let over blanks for lack of a better word and they just grab one finish the machining to match what it was going to be liks SCJ and all the parts for that and same with CJ
Super Snake Steve
Post  DaveMcLain March 14th 2015, 10:14 am
Super Snake Steve wrote:Would you say they were let over blanks for lack of a better word and they just grab one finish the machining  to match what it was going to be liks SCJ and all the parts for that and same with CJ
I think so yes. It doesn't make any real difference either way. It is sort of like those old FE blocks that you see which use the 427 rear bulkhead with the bosses for the side oilier and pressure relief.
DaveMcLain
Post  Super Snake Steve March 14th 2015, 10:56 am
Could you machine a CJ or SCJ block with boss bulkhead to be a full on boss block to use boss heads and all cant see why someone would do that these days with so many other options out just wondering if it could be done
Super Snake Steve
Post  dfree383 March 14th 2015, 1:47 pm
Super Snake Steve wrote:Could you machine a CJ or SCJ block with boss bulkhead to be a full on boss block to use boss heads and all cant see why someone would do that these days with so many other options out just  wondering if it could be done
The boss block is different in other areas too, not just the front bulkhead.
